ArcGIS.Desktop.Core Namespace / EditingOptions Class
    EditingOptions Class Properties
    For a list of all members of this type, see EditingOptions members.
    Public Properties
     NameDescription
    Public Property Gets and sets if Move tool is to be activated after all paste operations.
    Public Property Gets and sets whether the merge tool merges z-aware polygons when they overlap.
    Public Property Gets and sets whether vertex editing is allowed while sketching.
    Public Property Gets and sets the feature linked annotation follow mode. This describes how new annotation aligns to the line or boundary feature it is following.
    Public Property Gets and sets the feature linked annotation placement mode for new annotation relative to the direction of the line or boundary feature it is following.
    Public Property Gets and sets whether attribute edits are automatically applied.
    Public Property Gets and sets whether feature linked annotation automatically follows linked line features.
    Public Property Gets and sets whether feature linked annotation automatically follows linked polygon features.
    Public Property Gets and sets whether edits are to be automatically saved.
    Public PropertyGets and sets whether edits are to be saved by time or operation when AutomaticallySaveEdits is true.
    Public Property Gets and sets whether the active editing tool is deactivated when saving or discarding edits.
    Public Property Gets the default fallback tool. This is the "esri_mapping_exploreTool".
    Public Property Gets and sets the sketch behavior on a touch pad (click + drag vs click-drag-click)
    Public Property Gets and sets option to enable resize for selected annotation feature.
    Public Property Gets and sets option to enable rotation for selected annotation feature.
    Public Property Gets and sets whether to enable control points on the sketch
    Public Property Gets and sets whether editing can be enabled and disabled from the Edit tab.
    Public Property Gets and sets whether the Escape key is enabled as a shortcut to cancel the active tool in Stereo maps.
    Public Property Gets and sets whether attribute validation is enforced.
    Public Property Gets and sets the current fallback tool. This tool will be activated when an editing tool is deactivated.
    Public Property Gets and sets whether double-click is enabled as a shortcut for Finish when sketching.
    Public Property Gets and sets whether the layer should be highlighted in the attributes window selection view when the selection changes.
    Public Property Gets and sets whether default values are initialized on a subtype change.
    Public Property Gets and sets whether Deflection is the default direction constraint. Set to false for Absolute to be the default direction constraint.
    Public Property Gets and sets whether Direction is the default constraint for input mode. Set to false for Distance to be the default constraint for input mode.
    Public Property Gets and sets whether only data from a single workspace can be edited within an edit session. Specify the workspace to be edited using the
    Public Property Gets and sets whether the editing toolbar is magnified.
    Public Property Gets and sets whether newly added layers are editable by default.
    Public PropertyGets and sets the time interval (in minutes) after which edits will be saved if AutomaticallySaveEdits is true and AutoSaveByTime is true.
    Public Property Gets and sets whether edits are saved when saving project.
    Public PropertyGets and sets the number of operations after which edits will be saved if AutomaticallySaveEdits is true and AutoSaveByTime is false.
    Public Property Gets and sets whether the dialog to confirm deletes is displayed.
    Public Property Gets and sets whether the dialog to confirm discard edits is displayed.
    Public Property Gets and sets whether dynamic constraints are displayed in the map
    Public Property Gets and sets whether the editing toolbar is visible.
    Public Property Gets and sets whether feature symbology is displayed in the sketch.
    Public Property Gets and sets whether geometric constraints are displayed when drawing.
    Public Property Gets and sets whether the dialog to confirm save edits is displayed.
    Public Property Gets and sets whether geometry is stretched proportionately when moving a vertex.
    Public Property Gets and sets whether topology is stretched proportionately when moving a topology element.
    Public Property Gets and sets the editing toolbar position.
    Public Property Gets and sets the editing toolbar size.
    Public Property Gets and sets the uncommitted attribute edits setting.
    Public Property Gets and sets the uncommitted geometry edits setting.
    Public Property Gets and sets whether feature linked annotation uses placement properties defined in the annotation class.
    Public Property Gets and sets whether a warning is displayed when subtypes are changed.
    Top
