ArcGIS.Core.Data.NetworkDiagrams Namespace / NetworkDiagram Class / FindInitialNetworkRows Method
Example
    Gets a IReadOnlyList of FindResultItems corresponding to the initial list of network rows used to generate the diagram. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function FindInitialNetworkRows() As IReadOnlyList(Of FindResultItem)
    public IReadOnlyList<FindResultItem> FindInitialNetworkRows()
    Return Value
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Find Initial Network Rows Used to create a Network Diagram
      // Find the utility network rows used to create a network diagram
      static void FindInitialNetworkRows(NetworkDiagram diagram)
        IReadOnlyList<FindResultItem> rows = diagram.FindInitialNetworkRows();
        foreach (FindResultItem findRow in rows)
          long objectID = findRow.ObjectID;
          Guid guid = findRow.GlobalID;
          GeometryType geometryType = findRow.GeometryType;
          int sourceID = findRow.SourceID;
    Requirements
