ArcGIS.Core.Data.NetworkDiagrams Namespace / NetworkDiagram Class / GetConsistencyState Method
Example
    Gets the NetworkDiagramConsistencyState of the network diagram. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetConsistencyState() As NetworkDiagramConsistencyState
    public NetworkDiagramConsistencyState GetConsistencyState()
    Return Value
    The NetworkDiagramConsistencyState of the network diagram.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Get a list of Network Diagrams with inconsistent ConsistencyState
      static List<NetworkDiagram> GetInconsistentDiagrams(UtilityNetwork utilityNetwork)
        // Get the DiagramManager from the utility network
        using (DiagramManager diagramManager = utilityNetwork.GetDiagramManager())
          List<NetworkDiagram> networkDiagrams = new List<NetworkDiagram>();
          // Loop through the network diagrams in the diagram manager
          foreach (NetworkDiagram diagram in diagramManager.GetNetworkDiagrams())
            NetworkDiagramInfo diagramInfo = diagram.GetDiagramInfo();
            // If the diagram is not a system diagram and is in an inconsistent state, add it to our list
            if (!diagramInfo.IsSystem &&
                diagram.GetConsistencyState() != NetworkDiagramConsistencyState.DiagramIsConsistent)
              networkDiagrams.Add(diagram);
            else
              diagram.Dispose(); // If we are not returning it we need to Dispose it
          return networkDiagrams;
    Get Diagram from DiagramLayer
      // Get the NetworkDiagram from a DiagramLayer and check its ConsistencyState
      static void GetDiagram(DiagramLayer diagramLayer)
        NetworkDiagram diagram = diagramLayer.GetNetworkDiagram();
        // Get the consistency state from the layer
        DiagramLayerConsistencyState diagramLayerConsistencyState = diagramLayer.ConsistencyState;
        // Or from the diagram
        NetworkDiagramConsistencyState diagramConsistencyState = diagram.GetConsistencyState();
    Requirements
