ArcGIS.Core.Data.NetworkDiagrams Namespace / NetworkDiagram Class / RemoveFlags Method
The type of NetworkDiagramFlagType to remove.
    RemoveFlags Method
    Removes the flags in this network diagram. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub RemoveFlags( _
       ByVal flagType As NetworkDiagramFlagType _
    public void RemoveFlags(
       NetworkDiagramFlagType flagType
    Parameters
    flagType
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Remarks
    This routine generates its own editing transaction, and therefore cannot be wrapped in a separate transaction. Because the editing performed by this routine cannot be undone, this routine can also not be called within an editing session. All edits in the current edit session must be saved or discarded before calling this routine.
    Requirements
