ArcGIS.Core.Data.NetworkDiagrams Namespace / NetworkDiagram Class / SaveLayout Method
The NetworkDiagramSubset of the geometries to save.
Indicates whether the vertices are kept when reconnecting the edges.
Example
    SaveLayout Method
    Saves the layout of diagram elements. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SaveLayout( _
       ByVal subset As NetworkDiagramSubset, _
       ByVal keepVertices As Boolean _
    public void SaveLayout(
       NetworkDiagramSubset subset,
       bool keepVertices
    Parameters
    subset
    keepVertices
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Remarks
    Example
    Change the Layout of a Network Diagram
      // Change the layout of a network diagram by querying for all the diagram elements, editing their shapes,
      static void ChangeDiagramLayout(DiagramManager diagramManager, string diagramName)
        // Retrieve a diagram
        using (NetworkDiagram diagramTest = diagramManager.GetNetworkDiagram(diagramName))
          // Create a DiagramElementQueryByElementTypes query object to get the diagram elements we want to work with
          DiagramElementQueryByElementTypes query = new DiagramElementQueryByElementTypes();
          query.QueryDiagramJunctionElement = true;
          query.QueryDiagramEdgeElement = true;
          query.QueryDiagramContainerElement = true;
          // Retrieve those diagram elements
          DiagramElementQueryResult elements = diagramTest.QueryDiagramElements(query);
          // Create a NetworkDiagramSubset object to edit this set of diagram elements
          NetworkDiagramSubset subset = new NetworkDiagramSubset();
          subset.DiagramJunctionElements = elements.DiagramJunctionElements;
          subset.DiagramEdgeElements = elements.DiagramEdgeElements;
          subset.DiagramContainerElements = elements.DiagramContainerElements;
          // Save the new layout of the diagram elements
          diagramTest.SaveLayout(subset, true);
    Requirements
