ArcGIS.Core.Data Namespace / RelationshipClass Class / GetRowsRelatedToOriginRows Method
The ObjectIDs from the origin tables rows.
Example
    Gets the rows from the destination table that are related to the origin row object IDs. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetRowsRelatedToOriginRows( _
       ByVal originObjectIDs As IEnumerable(Of Long) _
    ) As IReadOnlyList(Of Row)
    public IReadOnlyList<Row> GetRowsRelatedToOriginRows(
       IEnumerable<long> originObjectIDs
    Parameters
    originObjectIDs
    Return Value
    A list with the related destination tables Rows. If originObjectIDs is an empty list or none of its content (i.e., OIDs) matches any row in the relationship class, an empty list will be returned.
    Exceptions
    ExceptionDescription
    originObjectIDs is null.
    A geodatabase-related exception has occurred.
    Remarks
    A common pattern is to generate the list of ObjectIDs from a Selection.
    Example
    Getting Rows related by RelationshipClass
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
        using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.luCodeViolationHasInspections"))
        using (FeatureClass violationsFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.luCodeViolation"))
        using (Table inspectionTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.luCodeInspection"))
          List<Row> jeffersonAveViolations = new List<Row>();
          QueryFilter queryFilter = new QueryFilter { WhereClause = "LOCDESC LIKE '%Jefferson%'" };
          using (RowCursor rowCursor = violationsFeatureClass.Search(queryFilter, false))
            while (rowCursor.MoveNext())
              jeffersonAveViolations.Add(rowCursor.Current);
          IReadOnlyList<Row> relatedOriginRows = null;
          IReadOnlyList<Row> relatedDestinationRows = null;
          try
            QueryFilter filter = new QueryFilter { WhereClause = "ACTION = '1st Notice'" };
            using (Selection selection = inspectionTable.Select(filter, SelectionType.ObjectID, SelectionOption.Normal))
              relatedOriginRows = relationshipClass.GetRowsRelatedToDestinationRows(selection.GetObjectIDs());
            bool containsJeffersonAve = relatedOriginRows.Any(row => Convert.ToString(row["LOCDESC"]).Contains("Jefferson"));
            List<long> jeffersonAveViolationObjectIds = jeffersonAveViolations.Select(row => row.GetObjectID()).ToList();
            relatedDestinationRows = relationshipClass.GetRowsRelatedToOriginRows(jeffersonAveViolationObjectIds);
            bool hasFirstNoticeInspections = relatedDestinationRows.Any(row => Convert.ToString(row["ACTION"]).Contains("1st Notice"));
          finally
            Dispose(jeffersonAveViolations);
            Dispose(relatedOriginRows);
            Dispose(relatedDestinationRows);
      void Dispose(IEnumerable<Row> rows)
        foreach (Row row in rows)
          row.Dispose();
    Deleting a Relationship
            if (!rowCursor.MoveNext())
              return;
            using (Row jeffersonAveViolation = rowCursor.Current)
              IReadOnlyList<Row> relatedDestinationRows = relationshipClass.GetRowsRelatedToOriginRows(new List<long>
                  { jeffersonAveViolation.GetObjectID() });
              try
                EditOperation editOperation = new EditOperation();
                editOperation.Callback(context =>
                  foreach (Row relatedDestinationRow in relatedDestinationRows)
                    try
                      relationshipClass.DeleteRelationship(jeffersonAveViolation, relatedDestinationRow);
                    catch (GeodatabaseRelationshipClassException exception)
                      Console.WriteLine(exception);
                }, relationshipClass);
                bool editResult = editOperation.Execute();
              finally
                foreach (Row row in relatedDestinationRows)
                  row.Dispose();
    Requirements
