ArcGIS.Desktop.Layouts Namespace / ElementFactory Class / CreateMapFrameElement Method
The parent element container
The map frame location (point), envelope, or polygon
The map (to be) associated with the frame (can be null)
An element name (optional)
Select after create flag (default is true) (optional)
Additional element properties (optional)
Example
    CreateMapFrameElement Method (ElementFactory)
    Create a map frame element based on the input map frame polygon and map URI. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CreateMapFrameElement( _
       ByVal elementContainer As IElementContainer, _
       ByVal frameOrLocation As Geometry, _
       ByVal map As Map, _
       Optional ByVal elementName As String, _
       Optional ByVal select As Boolean, _
       Optional ByVal elementInfo As ElementInfo _
    ) As MapFrame
    Parameters
    elementContainer
    frameOrLocation
    map
    elementName
    select
    elementInfo
    Return Value
    Exceptions
    ExceptionDescription
    Empty or null geometry
    frameOrLocation - invalid geometry type
    elementContainer must be a layout or group element (on a layout)
    Remarks
    Graphic layers are not valid containers for map frames. If the element container is a Layout then the element gets added to the root level of the layout TOC at the top most position. If the element container is a GroupElement then it gets added to the group at the topmost position.
    If a point is provided as the frame geometry then a default extent will be applied.
    Example
    Create Map Frame and Set Camera
      //Create a map frame and set its camera by zooming to the extent of an existing bookmark.
      //Construct on the worker thread
      //Build 2D envelope geometry
      Coordinate2D mf_ll = new Coordinate2D(6.0, 8.5);
      Coordinate2D mf_ur = new Coordinate2D(8.0, 10.5);
      Envelope mf_env = EnvelopeBuilderEx.CreateEnvelope(mf_ll, mf_ur);
      //Reference map, create MF and add to layout
      MapProjectItem mapPrjItem = Project.Current.GetItems<MapProjectItem>()
                           .FirstOrDefault(item => item.Name.Equals("Map"));
      Map mfMap = mapPrjItem.GetMap();
      Bookmark bookmark = mfMap.GetBookmarks().FirstOrDefault(
                            b => b.Name == "Great Lakes");
      MapFrame mfElm = ElementFactory.Instance.CreateMapFrameElement(
                           layout, mf_env, mfMap, "New Map Frame");
      //Zoom to bookmark
      mfElm.SetCamera(bookmark);
    Create Map Frame 1
      //Note: QueuedTask.Run
      //Build geometry
      Coordinate2D ll = new Coordinate2D(2.0, 4.5);
      Coordinate2D ur = new Coordinate2D(4.0, 6.5);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      MapFrame mfElm = ElementFactory.Instance.CreateMapFrameElement(layout, env, map);
    Create Map Frame 2
      //Note: Must be on QueuedTask.Run(() => { ...
      //Build geometry
      Coordinate2D ll = new Coordinate2D(4.0, 2.5);
      Coordinate2D ur = new Coordinate2D(7.0, 5.5);
      layout, env.Center, map);
    Requirements
