Public Function GetSubtypes() As IReadOnlyList(Of Subtype)
public IReadOnlyList<Subtype> GetSubtypes()
Return Value
A IReadOnlyList of the table's subtype codes.
| Exception | Description |
| System.NotSupportedException | The definition does not support this operation (e.g., the table is a shapefile). |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
// Must be called within QueuedTask.Run
string GetDomainStringFromField(Row row, Field field)
// Get the table and table definition from the Row
using (Table table = row.GetTable())
using (TableDefinition tableDefinition = table.GetDefinition())
// Get name of subtype field
string subtypeFieldName = tableDefinition.GetSubtypeField();
// Get subtype, if any
Subtype subtype = null;
if (subtypeFieldName.Length != 0)
// Get value of subtype field for this row
object varSubtypeCode = row[subtypeFieldName];
long subtypeCode = (long)varSubtypeCode;
// Get subtype for this row
subtype = tableDefinition.GetSubtypes().First(x => x.GetCode() == subtypeCode);
// Get the coded value domain for this field
CodedValueDomain domain = field.GetDomain(subtype) as CodedValueDomain;
// Return the text string for this field
if (domain != null)
return domain.GetName(row[field.Name]);
return row[field.Name].ToString();
