ArcGIS.Desktop.Catalog Namespace / FolderConnectionProjectItem Class
    FolderConnectionProjectItem Class Methods
    For a list of all members of this type, see FolderConnectionProjectItem members.
    Public Methods
     NameDescription
    Public Method Indicates if metadata is editable for the item. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Copy metadata from Item. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Delete certain content from the metadata of the current item. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Determines if the given object is identical to this object. (Inherited from ArcGIS.Desktop.Core.Item)
    Public MethodOverloaded.  (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Gets a hash code associated with this item. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Browses the contents of an item. Returns a snapshot collection of of the item's children. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Gets the item’s metadata XML document as a string. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Called when the Item becomes the current root item in the Catalog View. (Inherited from ArcGIS.Desktop.Core.Item)
    Public MethodOverridden.  Called when the item is expanded.
    Public MethodRefreshes the collection of children. Use ArcGIS.Desktop.Core.Item.IsMainThreadRequired to determine the correct thread for performing a refresh. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Repair the path (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Save the metadata of the current item as HTML. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Save the metadata of the current item using customized XSLT. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Save the metadata of the current item as XML. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Search (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Changes the alias value on the given item. This method will return false if the item is not a folder connection. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Sets the item’s metadata to the XML document provided as a string. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Updates metadata with the current properties of the item. Metadata is created for the item if it doesn't already exist. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Override the default ToString() method. (Inherited from ArcGIS.Desktop.Core.Item)
    Public Method Upgrade the metadata of the current item. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item)
    Top
    Protected Methods
     NameDescription
    Protected Internal MethodAdds the collection of items to the item's child collection (Inherited from ArcGIS.Desktop.Core.Item)
    Protected Internal MethodRemoves all items from the item's child collection (Inherited from ArcGIS.Desktop.Core.Item)
    Protected Internal Method Gets the children of this item (Inherited from ArcGIS.Desktop.Core.Item)
    Protected Internal Method Gets the container type (Inherited from ArcGIS.Desktop.Core.Item)
    Protected Internal MethodCheck if the item contains the specified child item in its child collection (Inherited from ArcGIS.Desktop.Core.Item)
    Protected Internal MethodInsert the child item into the item's child collection at the specified index (Inherited from ArcGIS.Desktop.Core.Item)
    Protected MethodOverloaded.  (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase)
    Protected Internal MethodRemove the specified item from the item's child collection (Inherited from ArcGIS.Desktop.Core.Item)
    Protected Internal Method Remove the collection of items from the item's child collection (Inherited from ArcGIS.Desktop.Core.Item)
    Protected Internal Method Derived classes can override this method (Inherited from ArcGIS.Desktop.Core.Item)
    Top
