ListFieldConflictFilters
Summary
The ListFieldConflictFilters function lists the fields in a versioned feature class, table, or feature service layer that have field conflict filters applied.
Syntax
ListFieldConflictFilters(table)
Parameter Explanation Data Type
table
Input geodatabase table, feature class, or feature service layer.
String
Return value
Data Type Explanation
String
A list containing strings for each field name that has conflict filters applied is returned.
Code sample
ListFieldConflictFilters example 1
List field conflict filters.
import arcpy
# Get a list of fields with conflict filters applied and print the name.
filteredFields = arcpy.da.ListFieldConflictFilters('C:/MyProject/municipal.sde/Primary_UG')
for field in filteredFields:
    print(field)
ListFieldConflictFilters example 2
List the field conflict filters for a feature service.
import arcpy
filteredFields = arcpy.da.ListFieldConflictFilters('https://myserver.com/server/rest/services/MyService/FeatureServer/0')
    print(field)
