Remove Field Conflict Filter (Data Management Tools)
Summary
Removes a field conflict filter for a given field in a geodatabase table or feature class.
Field conflict filters can be applied to versioned tables or feature classes to prevent conflicts from being identified when the same attribute is updated in the parent and child versions. Field conflict filters only apply for reconciles in which conflicts are defined by attribute.
Usage
  • When running from the tool dialog, only fields that already have filters applied will be displayed.
  • The ArcPy function arcpy.da.ListFieldConflictFilters can be used to identify fields that have filters applied.
Parameters
Label Explanation Data type
Input Table
Table or feature class containing the field or fields to be removed as conflict filters.
Table View
Field Name
Field or list of fields to be removed as conflict filters.
Field
Derived output
Updated Input Table
The updated input dataset.
Table View
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
