Accessing parameters in a script tool
The image below shows a script tool dialog box with three parameters: an input workspace, a clip feature class, and an output workspace. All feature classes in the input workspace are clipped to the clip feature class (using the Clip tool) and written to the output workspace.
In the image above, once parameter values have been entered on the tool dialog box and the Run button is clicked, the script reads the values of the parameters using the GetParameterAsText function, as follows:
import arcpy
# Read the parameter values:
# 1: input workspace
# 2: input clip features
# 3: output workspace
in_workspace = arcpy.GetParameterAsText(0)
clip_features = arcpy.GetParameterAsText(1)
out_workspace = arcpy.GetParameterAsText(2)
arcpy.env.workspace = in_workspace
sys.argv
In Python, the sys.argv provides an alternative for reading parameter values. The example above could be rewritten to use sys.argv as below. Note that the index of the arguments change from the GetParameterAsText function. This is because the 0-index (sys.argv[0]) returns the script file path and name.
import arcpy
import sys
in_workspace = sys.argv[1]
clip_features = sys.argv[2]
out_workspace = sys.argv[3]
sys.argv has limitations on the number of characters it can accept. The GetParameterAsText function has no character limit. For this reason alone, it is recommended that you use the GetParameterAsText function.
