LayerElevation
Summary
The LayerElevation class allows you to define height characteristics for 3D layers in a Map.
Discussion
For spatial data to be displayed in 3D, you can set height options for layers in the 3D Layers category of your local or global scene. This includes defining the layer's elevationMode and verticalUnits as well as optionally defining a cartographicOffset.
The elevationMode allows you to choose where a feature renders in relation to the Ground or custom elevation surface. See the ElevationSurface class for more examples on working with the Ground or custom elevation surfaces. A cartographic offset can be applied to adjust where features are drawn vertically relative to the base height. Use the vertical units property in situations where your Z values may have a different linear unit than your XY values.
For more information concerning the configuration of layer elevation settings in ArcGIS Pro, review the Define height characteristics for layers help topic.
3D layers may or may not support all elevation modes. Use error handling to set the desired elevation mode for a given layer type. See examples below for how to do this.
Properties
| Name | Explanation | Data type |
cartographicOffset (Read and Write) |
Gets and sets the cartographic offset. The offset can be applied to adjust where features are drawn vertically relative to the base height established by the |
Double |
elevationMode (Read and Write) |
Gets and sets the elevation mode that controls the layer's height. Layers in the 3D Layers category in the Contents pane support |
String |
verticalExaggeration (Read and Write) |
Gets and sets the vertical exaggeration. All features are exaggerated based on the value specified. The units of this value match the Vertical Units. This only applies if the |
Double |
verticalUnits (Read and Write) |
Gets or sets the vertical units for the layer. If the data source of a layer has a vertical coordinate system defined, the elevation unit of the layer is the same as the linear unit of the vertical coordinate system. Note:The vertical units displayed in Elevation category in the Layer Properties dialog, may display a value of "Data source vertical units" but the |
String |
Methods
setElevationMode(elevation_mode, expression, surface)
The layer's base height is configured using one or more parameters depending on the elevation_mode that is specified.
elevation_mode |
Below is a list of valid strings.
String |
expression |
An optional VB Script or Arcade expression to be applied depending on the specified Note:VB Script is deprecated in Windows. It is recommended to use Arcade. |
String |
surface |
An optional ElevationSurface to be applied depending on the specified |
Object |
setVerticalUnits({vertical_units})
A string constant that sets the elevation vertical units. It is recommended that vertical units always match the horizontal units of the layer when no vertical coordinate system is present. There may be cases, for example, where a dataset was created with horizontal linear units of meters but the vertical units are in feet.
It's important to define a vertical coordinate system when working with 3D data. If the data source of a layer has a vertical coordinate system defined, the elevation unit of the layer is the same as the linear unit of the vertical coordinate system.
vertical_units (Optional) |
The default value is METERS. |
String |
Code sample
The following script will iterate over 3D layers in your scene and set their elevation mode to On the ground.
import arcpy
aprx = arcpy.mp.ArcGISProject("C:/projects/redlands/redlands.aprx")
m = aprx.listMaps("Scene")[0]
for lyr in m.listLayers():
e = lyr.elevation
# Use try/except for layers that support on the ground and
# skip over layers that do not support this elevation mode
try:
e.setElevationMode('ON_THE_GROUND')
except Exception as e:
print(f"An error occurred: {e} for {lyr.name}")
aprx.save()
The following script will iterate over 3D layers in your scene and set their elevation mode to Relative to a custom surface with an arcade expression of 50.
import arcpy
e = lyr.elevation
try:
e.setElevationMode('RELATIVE_TO_CUSTOM_SURFACE','50',s)
aprx.save()
The following script will iterate over 3D layers in your scene and set their elevation mode to Absolute height based on the features Z values.
import arcpy
e = lyr.elevation
try:
e.setElevationMode('ABSOLUTE_HEIGHT', 'Shape.Z')
aprx.save()
The following script will iterate over 3D layers in your scene and set the cartographic offset to 100 if the current offset is 0.
import arcpy
e = lyr.elevation
if e.cartographicOffset == 0:
e.cartographicOffset = 100
aprx.save()
