ODCostMatrixSolverProperties
Summary
Provides access to analysis properties from an origin-destination (OD) cost matrix network analysis layer. The GetSolverProperties function is used to obtain an ODCostMatrixSolverProperties object from an OD cost matrix network analysis layer.
Discussion
The ODCostMatrixSolverProperties object provides read and write access to all the analysis properties of an OD cost matrix network analysis layer. The object can be used to modify the desired analysis properties of the OD cost matrix layer, and the corresponding layer can be resolved to determine the appropriate results. A new OD cost matrix layer can be created using the Make OD Cost Matrix Analysis Layer geoprocessing tool. Obtaining the ODCostMatrixSolverProperties object from a new OD cost matrix layer allows you to reuse the existing layer for subsequent analyses rather than create a layer for each analysis, which can be slow.
After modifying the properties on the ODCostMatrixSolverProperties object, the corresponding layer can be immediately used with other functions and geoprocessing tools. There is no refresh or update of the layer required to honor the changes modified through the object.
Properties
| Name | Explanation | Data type |
accumulators (Read and Write) |
Provides the ability to get or set a list of network cost attributes that are accumulated as part of the analysis. An empty list, |
String |
attributeParameters (Read and Write) |
Provides the ability to get or set the parameterized attributes to be used in the analysis. The property returns a Python dictionary. The dictionary key is a two-value tuple consisting of the attribute name and the parameter name. The value for each item in the dictionary is the parameter value. Parameterized network attributes are used to model some dynamic aspect of an attribute's value. For example, a tunnel with a height restriction of 12 feet can be modeled using a parameter. In this case, the vehicle's height in feet should be specified as the parameter value. If the vehicle is taller than 12 feet, this restriction will then evaluate to Attempting to modify the Do not attempt to modify the
Modify the
If the network analysis layer does not have parameterized attributes, this property returns |
Dictionary |
defaultCutoff (Read and Write) |
Provides the ability to get or set the default impedance value at which to cut off searching for destinations for a given origin. A value of None is used to specify that no cutoff should be used. |
Double |
defaultTargetDestinationCount (Read and Write) |
Provides the ability to get or set the number of destinations to find for each origin. A value of None is used to specify that all destinations should be found. |
Integer |
ignoreInvalidLocations (Read and Write) |
Specifies whether invalid input locations will be ignored. Typically, locations are invalid if they cannot be located on the network. When invalid locations are ignored, the solver will skip them and attempt to perform the analysis using the remaining locations.
String |
impedance (Read and Write) |
Provides the ability to get or set the network cost attribute used as impedance. This cost attribute is minimized while determining the routes between origins and destinations. |
String |
outputPathShape (Read and Write) |
Controls whether a straight line is generated between each origin-destination pair in the output OD cost matrix. The following is a list of possible values:
String |
restrictions (Read and Write) |
Provides the ability to get or set a list of restriction attributes that are applied for the analysis. An empty list, |
String |
solverName (Read only) |
Returns the name of the solver being referenced by the network analysis layer used to obtain the solver properties object. The property always returns the string value OD Cost Matrix Solver when accessed from a |
String |
timeOfDay (Read and Write) |
Provides the ability to get or set the departure date and time from the origins. A value of None can be used to specify that no date and time should be used. Instead of using a particular date, a day of the week can be specified using the following dates:
For example, to specify that the route from each origin should start at 8:00 a.m. on Wednesday, specify the value as datetime.datetime(1900, 1, 3, 8,0,0). The |
DateTime |
timeZoneUsage (Read and Write) |
Specifies the time zone of the
When solving an OD cost matrix analysis that spans across multiple time zones and a start time is set, all origins must be in the same time zone. |
String |
travelMode (Read only) |
Accesses the travel mode set on a network analysis layer as an |
Object |
useHierarchy (Read and Write) |
Controls the use of the hierarchy attribute while performing the analysis. The following is a list of possible values:
String |
uTurns (Read and Write) |
Provides the ability to get or set the policy that indicates how the U-turns at junctions that could occur during network traversal between stops are being managed by the solver. The following is a list of possible values:
String |
Methods
applyTravelMode(travel_mode)
Updates the analysis properties of a network analyst layer based on a travel mode object. The updated network analyst layer can then be solved to complete the analysis.
When a network analyst layer is created, it is assigned default values for all of its analysis properties. The individual analysis properties can be updated using a solver properties object obtained from the network analyst layer. A travel mode stores a predefined set of analysis settings that help to perform a particular analysis, such as a walking time travel mode that stores the analysis settings required to perform a time-based walking analysis.
Using the applyTravelMode method, all the analysis settings that are defined in a travel mode can be applied at once. After the analysis properties are updated, the network analyst layer can be solved to complete the analysis.
If there is an error when updating the solver properties, such as when the provided travel mode references properties that don't exist on the current network dataset or references properties that are no longer applicable to the network dataset that was used to create the network analyst layer corresponding to the solver properties object, no exceptions are raised. The method will execute successfully, but you will get errors when you try to solve such a network analyst layer.
If the travel_mode parameter does not reference a travel mode object or a string, a TypeError exception is raised. If the travel_mode parameter references a string and the string cannot be internally converted to a valid string representation of a travel mode object, a ValueError exception is raised.
travel_mode |
A variable that references a travel mode object derived from a network dataset. A list of travel mode objects can be obtained by calling the |
Object |
Code sample
The script shows how to update the OD Cost Matrix solver properties through a full workflow. This is based on the tutorial network dataset of the San Francisco region.
# Name: ODSolverProperties_Workflow.py
# Description: Finds the full matrix of distribution centers and stores and then
# a second solve that only finds the closest distribution center
# Requirements: Network Analyst extension
# Import system modules
import arcpy
from arcpy import env
import os
import datetime
try:
# Set environment settings
output_dir = r"C:\Data"
# The NA layer's data will be saved to the workspace specified here
env.workspace = os.path.join(output_dir, "Output.gdb")
env.overwriteOutput = True
# Set local variables
input_gdb = "C:/Data/SanFrancisco.gdb"
network = os.path.join(input_gdb, "Transportation", "Streets_ND")
layer_name = "StoresToDCs"
travel_mode = "Driving Time"
in_origins = os.path.join(input_gdb, "Analysis/Stores")
in_destinations = os.path.join(input_gdb, "Analysis/CentralDepots")
full_matrix = os.path.join(output_dir, "Output.gdb", "full_matrix")
closest_DC = os.path.join(output_dir, "Output.gdb", "closest_DC")
# Create a new Origin Destination layer.
result_object = arcpy.na.MakeODCostMatrixAnalysisLayer(network,
layer_name, travel_mode)
# Get the layer object form the result object. The origin destination layer
# can now be referenced using the layer object.
layer_object = result_object.getOutput(0)
# Get the names of all the sublayers within the Origin Destination layer.
sub_layer_names = arcpy.na.GetNAClassNames(layer_object)
# Store the layer names that we will use later
origins_layer_name = sub_layer_names["Origins"]
destination_layer_name = sub_layer_names["Destinations"]
lines_layer_name = sub_layer_names["ODLines"]
# Load the stores locations as origins.
arcpy.na.AddLocations(layer_object, origins_layer_name, in_origins,
# Load the distribution center location as destinations
arcpy.na.AddLocations(layer_object, destination_layer_name, in_destinations,
# Solve the origin destination layer
arcpy.na.Solve(layer_object)
# Save the resulting line sublayer
arcpy.management.CopyFeatures(lines_layer_name, full_matrix)
# Get the solver properties object from the origin destination layer
solverProps = arcpy.na.GetSolverProperties(layer_object)
# Update the destination count to 1
solverProps.defaultTargetDestinationCount = 1
arcpy.management.CopyFeatures(lines_layer_name, closest_DC)
except Exception as e:
# If an error occurred, print line number and error message
import traceback
import sys
tb = sys.exc_info()[2]
print("An error occurred on line %i" % tb.tb_lineno)
print(str(e))
This script shows how to apply the TruckingTime travel mode to an existing layer.
#Get the OD cost matrix layer object from a layer named "OD Matrix" in
#the map
doc = arcpy.mp.ArcGISProject('current')
map_obj = doc.listMaps()[0]
od_layer = map_obj.listLayers('OD Matrix')[0]
#Get the Trucking Time travel mode from the network dataset
desc = arcpy.Describe(od_layer)
travel_modes = arcpy.na.GetTravelModes(desc.network.catalogPath)
trucking_mode = travel_modes["Trucking Time"]
#Apply the travel mode to the analysis layer
solver_properties = arcpy.na.GetSolverProperties(od_layer)
solver_properties.applyTravelMode(trucking_mode)
