KrigingModelOrdinary
Summary
Defines the Ordinary Kriging model. The available model types are Spherical, Circular, Exponential, Gaussian, and Linear.
Discussion
The KrigingModelOrdinary object is used in the Kriging tool.
Ordinary Kriging assumes the model:
\(Z(s) = µ + ε(s)\)
The default value for lagSize is set to the default output cell size.
For majorRange, partialSill, and nugget, a default value will be calculated internally if nothing is specified.
Syntax
KrigingModelOrdinary({semivariogramType}, {lagSize}, {majorRange}, {partialSill}, {nugget})
Name Explanation Data type
semivariogramType
(Optional)
Semivariogram model to be used.
  • SPHERICAL—Spherical semivariogram model.
  • CIRCULAR—Circular semivariogram model.
  • EXPONENTIAL—Exponential semivariogram model.
  • GAUSSIAN—Gaussian (or normal distribution) semivariogram model.
  • LINEAR—Linear semivariogram model with a sill.
The default value is SPHERICAL.
String
lagSize
(Optional)
The lag size to be used in model creation. The default is the output raster cell size.
Double
majorRange
(Optional)
Represents a distance beyond which there is little or no correlation.
Double
partialSill
(Optional)
The difference between the nugget and the sill.
Double
nugget
(Optional)
Represents the error and variation at spatial scales too fine to detect. The nugget effect is seen as a discontinuity at the origin.
Double
Properties
semivariogramType
(Read and Write)
String
lagSize
(Read and Write)
Double
majorRange
(Read and Write)
Double
partialSill
(Read and Write)
Double
nugget
(Read and Write)
Double
Code sample
KrigingModelOrdinary example 1 (Python window)
Demonstrates how to create a KrigingModelOrdinary object and use it in the Kriging tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
kModelOrdinary = KrigingModelOrdinary("CIRCULAR", 70000, 250000, 180000, 34000)
outKrigingOrd1 = Kriging("ca_ozone_pts.shp", "ELEVATION", kModelOrdinary, 2000, RadiusVariable(),"")
outKrigingOrd1.save("C:/sapyexamples/output/kordinary1")
KrigingModelOrdinary example 2 (stand-alone script)
Calculates a kriging surface using the KrigingModelOrdinary object.
# Name: KrigingModelOrdinary_Ex_02.py
# Description: Uses the KrigingModelOrdinary object to run the Kriging tool.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inPointFeature = "ca_ozone_pts.shp"
outVarRaster = "C:/sapyexamples/output/ovariance2"
# Create KrigingModelOrdinary Object
lagSize = 70000
majorRange = 250000
partialSill = 180000
nugget = 34000
kModelOrdinary = KrigingModelOrdinary("CIRCULAR", lagSize, majorRange,
                                         partialSill, nugget)
# Run Kriging
outKrigingOrd2 = Kriging(inPointFeature, "ELEVATION", kModelOrdinary, 2000,
                     RadiusFixed(200000, 10), outVarRaster)
# Save the output
outKrigingOrd2.save("C:/sapyexamples/output/kordinary2")
