RemapValue
Summary
A list identifying what the individual input values should be reclassified to in an output raster.
RemapValue remap table image
RemapValue remap table for the Reclassify functions.
Discussion
The RemapValue object can be used in the Reclassify tool and the WOTable class.
The oldValue value can be assigned to NoData by entering NoData (a string) as the newValue value.
Reclassifying individual values is usually done when the input values are categorical, for example, land use, or when changing only a few values.
Syntax
RemapValue(remapTable)
Name Explanation Data type
remapTable
The remap table to be used to remap the old values to new values.
It defines a list to be used to remap the input values. It is a list of lists, with the inner lists being composed of two components.
The components are:
  • oldValue—Represents an original value from the base raster (data type: double, long, string).
  • newValue—Is the new reclassified value (data type: long).
The oldValue can be numeric or string. The newValue must be integer.
List
Properties
remapTable
(Read and Write)
The remap table that is used to remap the original values to new values.
List
Code sample
RemapValue example 1 (Python window)
Demonstrates how to create a RemapValue class and use it in the Reclassify function within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myRemapValue = RemapValue([["Water", 0], ["Wetlands", 0], ["Barrenland", 1], ["Brushtransitional", 2], ["Builtup",3]])
outReclassRV = Reclassify("landuse", "LANDUSE2", myRemapValue)
outReclassRV.save("C:/sapyexamples/output/reclassrv")
RemapValue example 2 (stand-alone script)
Performs a reclassification with the RemapValue class.
# Name: RemapValue_Ex_02.py
# Description: Uses the RemapValue object to run Reclassify tool.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = "negs"
# Define the RemapValue Object
myRemapVal = RemapValue([[-3,9],[0,1],[3,-4],[4,5],[5,6],[6,4],[7,-7]])
# Run Reclassify
outReclassRV = Reclassify(inRaster, "VALUE", myRemapVal, "")
# Save the output
outReclassRV.save("C:/sapyexamples/output/reclassrevar2")
