VectorField
Summary
Visualizes flow direction and magnitude information in a raster with vector symbols.
Discussion
For more information about how this function works, see the Vector Field raster function.
The referenced raster dataset for the raster object is temporary. To make it permanent, you can call the raster object's save method.
Syntax
VectorField(raster_u_mag, raster_v_dir, {input_data_type}, {angle_reference_system}, {output_data_type})
Parameter Explanation Data Type
raster_u_mag
The first input raster, which is either the U value or the magnitude.
Raster
raster_v_dir
The second input raster, which is either the V value or the direction.
Raster
input_data_type
The type of vector field your inputs represent.
  • Unknown—It is unknown whether the inputs represent U-V or Magnitude-Direction.
  • Vector-UV—Input data represents U and V components.
  • Vector-MagDir—Input data represents magnitude and direction.
The default value is Vector-UV.
String
Specifies how the direction component was measured.
  • Geographic—0° points due north, and 90° points due east.
  • Arithmetic—0° points due east, and 90° points due north.
The default value is Geographic.
String
output_data_type
Specifies the type of vector field your output will represent.
  • Vector-UV—Output data represents U and V components.
  • Vector-MagDir—Output data represents magnitude and direction.
String
Return value
Data Type Explanation
Raster
The output raster.
Code sample
VectorField example 1
This example creates a vector field for a multidimensional dataset.
from arcpy.sa import *
out_vectorfield_raster = VectorField("magnitude", "direction", "Vector-MagDir",
                                 None, "Vector-UV")
out_vectorfield_raster.save("C:/arcpyExamples/outputs/vector_field_UV.crf")
VectorField example 2
# Import system modules
import arcpy
# Set the analysis environments
arcpy.env.workspace = "C:/arcpyExamples/data"
# Set the local variables
# create a multidimensional raster object from hycom.nc that
# contains 2 variables water_u and water_v
hycom_raster = arcpy.Raster("C:/data/hycom.nc", True)
# choose the 2 variables from hycom_raster as 2 multidimensional raster
in_raster_u_mag = Subset(hycom_raster, variables = "water_u")
in_raster_v_dir = Subset(hycom_raster, variables = "water_v")
# Run VectorField function
out_vectorField_raster = VectorField(in_raster_u_mag, in_raster_v_dir,
                                     "Vector-UV", "Geographic", "Vector-MagDir")
# Save the output
out_vectorField_raster.save("C:/arcpyExamples/vector_field_magdir.crf")
