An overview of the Spatial Analyst functions
The Spatial Analyst module (arcpy.sa) supports many functions in ArcPy for processing and creating rasters or raster objects. They are organized into related groupings in the following categories: Analysis, Appearance, Band Indices, Classification, Conversion, Correction, Data Management, Math, Reclass, Statistical, and Surface.
Some functions available with the arcpy.sa module require a Spatial Analyst or an Image Analyst license. Where applicable, the extension license requirements for each function are listed in the table below. All other functions can be used with an ArcGIS Pro Basic license.
The geoprocessing tools available in the Spatial Analyst toolbox are also available as geoprocessing functions in the arcpy.sa module.
Analysis
Function
License requirement
Anomaly
Creates a raster object that contains the anomaly pixel values of the input multidimensional raster based on a time-dimension interval and the anomaly calculation method.
Image Analyst or Spatial Analyst
Apply
Creates a raster object by applying a raster function or function chain to one or more input rasters.
ArcGIS Pro Basic
Foreach
Creates a raster object by applying a raster function or a customized function template to every slice in the input multidimensional raster.
HeatIndex
Calculates apparent temperature based on ambient temperature and relative humidity. The apparent temperature is often described as how hot it feels to the human body.
ArcGIS Pro Basic
TasseledCap
Creates a raster object by applying a tasseled cap transformation on an input raster.
ArcGIS Pro Basic
Threshold
Creates a raster object by dividing an input raster into two distinct classes in which a high-value class is displayed with light pixels and a low-value class is displayed with dark pixels.
ArcGIS Pro Basic
WindChill
Identifies dangerous winter conditions that, depending on exposure times to the elements, can result in frostbite or hypothermia.
ArcGIS Pro Basic
Appearance
Function
License requirement
ContrastBrightness
Creates an enhanced image by improving the contrast and brightness of the source image.
ArcGIS Pro Basic
Convolution
Performs filtering on the pixel values in an image, which can be used for sharpening an image, blurring an image, detecting edges within an image, or other kernel-based enhancements.
ArcGIS Pro Basic
Pansharpen
Creates a higher-resolution multiband image by fusing a lower-resolution multispectral image and a higher-resolution panchromatic image.
ArcGIS Pro Basic
Render
Creates a rendered raster object by applying symbology to the referenced raster dataset. This function is useful when displaying data in a Jupyter notebook.
ArcGIS Pro Basic
StatisticsHistogram
Computes the statistics and histogram of a raster.
ArcGIS Pro Basic
Stretch
Enhances an image by changing properties such as brightness, contrast, and gamma through multiple stretch types based on statistics.
ArcGIS Pro Basic
VectorFieldRenderer
Visualizes flow direction and magnitude information in a raster with vector symbols.
ArcGIS Pro Basic
Band Indices
Function
License requirement
BAI
Calculates the Burn Area Index (BAI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
CIg
Calculates the Green Chlorophyll Index (CIg) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
CIre
Calculates the Red-Edge Chlorophyll Index (CIre) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
ClayMinerals
Calculates the Clay Minerals (CM) ratio from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
EVI
Calculates the Enhanced Vegetation Index (EVI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
FerrousMinerals
Calculates the Ferrous Minerals (FM) ratio from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
GEMI
Calculates the Global Environmental Monitoring Index (GEMI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
GNDVI
Calculates the Green Normalized Difference Vegetation Index (GNDVI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
GVITM
Calculates the Green Vegetation Index for Landsat TM (GVITM) from a Landsat TM image and returns a raster object with the index values.
ArcGIS Pro Basic
IronOxide
Calculates the Iron Oxide (IO) ratio from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
MSAVI
Calculates the Modified Soil Adjusted Vegetation Index (MSAVI2) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
MTVI2
Calculates the Modified Triangular Vegetation Index (MTVI2) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
NBR
Calculates the Normalized Burn Ratio (NBR) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
NDBI
Calculates the Normalized Difference Built-up Index (NDBI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
NDMI
Calculates the Normalized Difference Moisture Index (NDMI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
NDSI
Calculates the Normalized Difference Snow Index (NDSI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
NDVI
Calculates the Normalized Difference Vegetation Index (NDVI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
NDVIre
Calculates the Red-Edge Normalized Difference Vegetation Index (NDVIre) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
NDWI
Calculates the Normalized Difference Water Index (NDWI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
PVI
Calculates the Perpendicular Vegetation Index (PVI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
RTVICore
Calculates the Red-Edge Triangulated Vegetation Index (RTVICore) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
SAVI
Calculates the Soil Adjusted Vegetation Index (SAVI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
SRre
Calculates the Red-Edge Simple Ratio (SRre) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
Sultan
Calculates Sultan's formula from a six-band 8-bit raster object and returns a three-band 8-bit raster object.
ArcGIS Pro Basic
TSAVI
Calculates the Transformed Soil Adjusted Vegetation Index (TSAVI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
VARI
Calculates the Visible Atmospherically Resistant Index (VARI) from a multiband raster object and returns a raster object with the index values.
ArcGIS Pro Basic
Classification
Function
License requirement
Classify
Classifies a raster dataset based on an Esriclassifier definition file (.ecd) and raster dataset inputs.
LinearUnmixing
Performs subpixel classification and calculates the fractional abundance of land-cover types for individual pixels.
RegionGrow
Groups adjacent pixels depending on the specified radius from the seed point.
SegMeanShift
Groups adjacent pixels that have similar spectral and spatial characteristics.
Conversion
Function
License requirement
Colormap
Transforms the pixel values to display the raster data as either a grayscale or an RGB color image based on a color scheme or specific colors in a color map file.
ArcGIS Pro Basic
ColormapToRGB
Converts a single-band raster with a color map to a three-band (red, green, and blue) raster.
ArcGIS Pro Basic
ColorspaceConversion
Converts the color model of a three-band unsigned 8-bit image from the hue, saturation, and value (HSV) to red, green, and blue (RGB) or vice versa.
ArcGIS Pro Basic
Complex
Computes the magnitude from complex values.
ArcGIS Pro Basic
Grayscale
Converts a multiband image to a single-band grayscale image. Specified weights are applied to each of the input bands, and a normalization is applied for output.
ArcGIS Pro Basic
RasterizeFeatures
Converts a polygon, polyline, or point feature class to a raster object.
ArcGIS Pro Basic
SpectralConversion
Applies a matrix to a multiband image to affect the color values of the output.
ArcGIS Pro Basic
UnitConversion
Converts pixels from one unit to another. It supports conversion of distance, speed, and temperature.
ArcGIS Pro Basic
VectorField
Combines and converts two rasters into a two-band raster that is of data type Magnitude-Direction or data type U-V.
ArcGIS Pro Basic
Correction
Function
License requirement
Speckle
Creates a raster object by removing speckle and smoothing out noise in radar datasets, while retaining edges and sharp features in the image.
ArcGIS Pro Basic
Data Management
Function
License requirement
ApplyEnvironment
Creates a new raster that is a copy of the input raster with the current environment settings being applied.
ArcGIS Pro Basic
CompositeBand
Creates a raster object by combining multiple rasters to form a multiband image.
ArcGIS Pro Basic
ExtractBand
Creates a raster object by extracting one or more bands from, or reordering the bands in, a multiband raster.
ArcGIS Pro Basic
Mask
Creates a raster object by specifying one or more NoData values or a range of valid pixel values.
ArcGIS Pro Basic
Resample
Creates a raster object by changing the spatial resolution of the input raster and sets rules for aggregating or interpolating values across the new pixel sizes.
ArcGIS Pro Basic
Subset
Creates a raster object that is a subset of the input multidimensional raster based on selected variables and dimension intervals.
ArcGIS Pro Basic
TransposeBits
Creates a raster object by unpacking the bits of the input pixel and mapping them to specified bits in the output pixel. The purpose of this function is to manipulate bits from a couple of inputs, such as the Landsat 8 quality band products.
ArcGIS Pro Basic
Math
Function
License requirement
Arithmetic
Performs an arithmetic operation between two rasters or between a raster and a scalar and returns a raster object with the operation applied.
ArcGIS Pro Basic
BandArithmetic
Performs an arithmetic operation on the bands of a multiband raster object and returns a raster object with the operation applied.
ArcGIS Pro Basic
RasterCalculator
Provides access to all existing math functions and returns a raster object with the mathematical operation applied.
Reclass
Function
License requirement
Remap
Categorizes the pixel values of a raster object into groups with specific values.
ArcGIS Pro Basic
ZonalRemap
Categorizes the pixel values of a raster object into groups based on zones defined in another raster and zone-dependent value mapping defined in a table.
ArcGIS Pro Basic
Statistical
Function
License requirement
ArgStatistics
Creates a raster object in which each pixel contains the band index at which that pixel reached the statistical argument. If the input raster is multidimensional, the output raster object will contain dimension values instead of band indices.
ArcGIS Pro Basic
Statistics
Calculates statistics for each cell of an image based on a defined focal neighborhood.
ArcGIS Pro Basic
Surface
Function
License requirement
AspectSlope
Creates a raster object that simultaneously displays the aspect and slope of a surface.
ArcGIS Pro Basic
ElevationVoidFill
Creates pixels on a raster object where holes exist in the elevation.
ArcGIS Pro Basic
ShadedRelief
Creates a color 3D representation of the terrain by merging the images from the elevation-coded and hillshade methods.
ArcGIS Pro Basic
