VfBinary
Summary
Defines the relationship between the vertical cost factor and the vertical relative moving angle through a binary function. If the vertical relative moving angle is greater than the low-cut angle and less than the high-cut angle, the vertical factor is set to the value associated with the zero factor; otherwise it is infinity.
Discussion
This object is used in the Distance Accumulation and Distance Allocation Spatial Analyst tools, as well as the Path Distance, Path Distance Allocation, and Path Distance Back Link Legacy Distance tools.
The vertical factor (VF) object defines the relationship between the vertical cost factor and the vertical relative moving angle (VRMA).
VF defines the vertical difficulty encountered in moving from one cell to the next.
VRMA identifies the slope angle between the FROM or processing cell and the TO cell.
When the VRMA is larger than the low-cut angle and smaller than the high-cut angle, the VF for moving between the two cells is set to the value associated with the zeroFactor. If the VRMA is greater than the highCutAngle or lower than the lowCutAngle, the VF is set to infinity.
Syntax
VfBinary({zeroFactor}, {lowCutAngle}, {highCutAngle})
| Name | Explanation | Data type |
zeroFactor (Optional) |
The The default value is 1.0. |
Double |
lowCutAngle (Optional) |
The VRMA degree defining the lower threshold, below which (less than) the VFs are set to infinity. The default value is -30.0. |
Double |
highCutAngle (Optional) |
The VRMA degree defining the upper threshold, beyond which (larger than) the VFs are set to infinity. The default value is 30.0. |
Double |
Properties
zeroFactor (Read and Write) |
The |
Double |
lowCutAngle (Read and Write) |
The VRMA degree defining the lower threshold, below which (less than) the VFs are set to infinity. |
Double |
highCutAngle (Read and Write) |
The VRMA degree defining the upper threshold, beyond which (larger than) the VFs are set to infinity. |
Double |
Code sample
Demonstrates how to create a VfBinary class and use it in the DistanceAccumulation tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myVerticalFactor = VfBinary(1.0, -30, 30)
outDistAccum = DistanceAccumulation("Source.shp", "", "elev.tif",
"cost.tif", "elev.tif",
myVerticalFactor)
outDistAccum.save("C:/sapyexamples/output/distAccumVfB.tif")
Performs a distance accumulation analysis using the VfBinary class.
# Name: VfBinary_Ex_02.py
# Description: Uses the VfBinary object to run the
# DistanceAccumulation tool
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inSourceData = "source.shp"
inCostRaster = "costraster.tif"
inElevation = "elev.tif"
# Create the VfBinary Object
zeroFactor = 1.0
lowCutAngle = -30
highCutAngle = 30
myVerticalFactor = VfBinary(zeroFactor, lowCutAngle, highCutAngle)
# Run DistanceAccumulation
outDistAccum = DistanceAccumulation(inSourceData, "", inElevation,
inCostRaster, inElevation,
myVerticalFactor)
# Save the output
outDistAccum.save("C:/sapyexamples/output/distaccumvfB2.tif")
