Catalog settings
System administrators can manage many ArcGIS Pro user application settings.
The settings described below should be added under the Catalog element in the Pro.settingsConfig file.
EnableIndexing
In the user interface, on the Indexing tab on the Options dialog box, click Create and manage your own index > Index items to access the corresponding setting.
Learn more about enabling and disabling indexing
Possible values are the following:
  • true (default)—Indexing is enabled.
  • false—Indexing is not enabled.
An example of this setting is shown below.
<EnableIndexing isLocked="true">false</EnableIndexing>
IndexNetworkConnections
In the user interface, on the Indexing tab on the Options dialog box, click Create and manage your own index > Content and schedule > Index project items in these locations > Network locations to access the corresponding setting.
Learn more about indexing network locations
  • true—Network locations are indexed.
  • false (default)—Network locations are not indexed.
<IndexNetworkConnections isLocked="true">true</IndexNetworkConnections>
MetadataCanDeleteGPHistory
In the user interface, on the Metadata tab on the Options dialog box, click Allow geoprocessing history to be deleted from metadata to access the corresponding setting.
Learn more about geoprocessing history and metadata
  • true (default)—Geoprocessing history can be deleted.
  • false—Geoprocessing history cannot be deleted.
<MetadataCanDeleteGPHistory isLocked="true">false</MetadataCanDeleteGPHistory>
MetadataEditor
In the user interface, on the Metadata tab on the Options dialog box, click Metadata editor to access the corresponding setting.
Learn more about metadata editors
  • PRO_CLASSIC (default)—The ArcGIS Pro metadata editor is used.
  • ARCGIS_PLATFORM—The ArcGIS metadata editor is used.
<MetadataEditor isLocked="true">PRO_CLASSIC</MetadataEditor>
Not all metadata styles are supported by both metadata editors. For example, the Item Description style is not supported by the ArcGIS editor, and the Dublin Core+ style is not supported by the ArcGIS Pro editor.
If you lock the MetadataEditor setting, it is important to lock the MetadataStyle setting to a compatible value. If you lock the MetadataEditor and MetadataStyle settings to incompatible values, the editor that is compatible with the specified metadata style is used automatically, and the lock on the specified editor value is overridden. A message on the Metadata tab on the Options dialog box indicates that the editor is not valid for the specified style.
MetadataStyle
In the user interface, on the Metadata tab on the Options dialog box, click Metadata style to access the corresponding setting.
Learn more about metadata styles
Possible values are those that appear in the Metadata Styles drop-down list. These include the following metadata styles that are provided with ArcGIS Pro and the names of any custom metadata style add-ins that have been installed.
  • Dublin Core+
  • FGDC CSDGM Metadata
  • INSPIRE Metadata Directive
  • ISO 19139 Metadata Implementation Specification GML3.2
  • Item Description (default)
  • North American Profile of ISO19115 2003
  • ISO 19115-3 XML Schema Implementation
<MetadataStyle isLocked="true">Item Description</MetadataStyle>
SearchIndexes
In the user interface, on the Indexing tab on the Options dialog box, click Use indexes managed by others to access the corresponding setting.
Learn more about managed indexes
  • A valid folder path.
If isLocked="true", the specified path is added to the list of managed indexes. Additional paths can be specified by placing a vertical bar symbol (|) between path names. Specified paths cannot be removed by the user; however, users are not blocked from adding more paths.
<SearchIndexes isLocked="true">\\dataserver1\WorldData_SearchIndex</SearchIndexes>
SkipServerConnections
In the user interface, on the Indexing tab on the Options dialog box, click Create and manage your own index > Content and schedule > Index project items in these locations > Enterprise geodatabases to access the corresponding setting.
Learn more about indexing enterprise geodatabases
  • true (default)—Enterprise geodatabases are not indexed.
  • false—Enterprise geodatabases are indexed.
<SkipServerConnections isLocked="true">false</SkipServerConnections>
SystemFavoritesFilePath
Use this setting to specify the path to the system favorites file. It does not have a corresponding user interface setting.
  • A valid path to a .json file. There is no default value.
<SystemFavoritesFilePath isLocked="true">\\dataserver1\TeamResources\SystemFavorites.json</SystemFavoritesFilePath>
