Map and Scene settings
System administrators can manage many ArcGIS Pro user application settings.
The settings described below should be added under the MapAndScene element in the Pro.settingsConfig file.
Learn more about map and scene options
DefaultBasemapJson
In the user interface, on the Map and Scene tab on the Options dialog box, click Basemap > Map to access the corresponding setting.
Possible values are the following:
FromPortal(The default basemap of your organization is added. This is the default.)A JSON object or CIM path corresponding to a custom basemap
Not set (An empty string. No basemap is added.)
An example of this setting is shown below.
<DefaultBasemapJson isLocked="true">FromPortal</DefaultBasemapJson>
DefaultSceneBasemapJson
In the user interface, on the Map and Scene tab on the Options dialog box, click Basemap > Scene to access the corresponding setting.
<DefaultSceneBasemapJson isLocked="true">FromPortal</DefaultSceneBasemapJson>
LayerVisibleByDefault
In the user interface, on the Map and Scene tab on the Options dialog box, click Add Layers and Tables > Layer visibility > Make newly added layers visible by default to access the corresponding setting.
true(default)false
<LayerVisibleByDefault isLocked="true">true</LayerVisibleByDefault>
DefaultSpatialReference
In the user interface, on the Map and Scene tab on the Options dialog box, click Spatial Reference to access the corresponding setting.
Not set (An empty string. The spatial reference of the first operational layer is used. This is the default.)
A spatial reference
.xmlfile
Set the default spatial reference through the application and access the location of the user configuration file from the registry key HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGISPro\Settings\UserConfigLocalRoaming. Within this user configuration file, locate the DefaultSpatialReference setting. Paste this XML inside your administrator setting definition in the Pro.settingsConfig file.
<DefaultSpatialReference isLocked="true">
<ProjectedCoordinateSystem
xsi:type='typens:ProjectedCoordinateSystem'
xmlns:xs='http://www.w3.org/2001/XMLSchema'
xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'
xmlns:typens='http://www.esri.com/schemas/ArcGIS/3.1.0'><
WKT>PROJCS["North_Pole_Lambert_Azimuthal_Equal_Area",
GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",
SPHEROID["WGS_1984",6378137.0,298.257223563]],
PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["False_Easting",0.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",0.0],
PARAMETER["Latitude_Of_Origin",90.0],
UNIT["Meter",1.0],
AUTHORITY["Esri",102017]]</WKT><
XOrigin>-12742200</
XOrigin><YOrigin>-12742200</
YOrigin><XYScale>10000</
XYScale><ZOrigin>-100000</
ZOrigin><ZScale>10000</
ZScale><MOrigin>-100000</
MOrigin><MScale>10000</
MScale><XYTolerance>0.001</
XYTolerance><ZTolerance>0.001</
ZTolerance><MTolerance>0.001</
MTolerance><HighPrecision>true</
HighPrecision><WKID>102017</
WKID><LatestWKID>102017</
LatestWKID></
ProjectedCoordinateSystem>
</DefaultSpatialReference>
ConfirmTransformation
In the user interface, on the Map and Scene tab on the Options dialog box, click Spatial Reference > Warn if transformation between geographic coordinate system is required to align data sources correctly to access the corresponding setting.
truefalse(default)
<ConfirmTransformation isLocked="true">true</ConfirmTransformation>
IgnoreBasemapForAutoTransform
In the user interface, on the Map and Scene tab on the Options dialog box, click Spatial Reference > Ignore the extents of basemap layers when listing and automatically choosing transformations to access the corresponding setting.
truefalse(default)
<IgnoreBasemapForAutoTransform isLocked="true">true</IgnoreBasemapForAutoTransform>
DefaultLabelEngine
In the user interface, on the Map and Scene tab on the Options dialog box, click Label Engine > Default label engine to access the corresponding setting.
Maplex(default)Standard
<DefaultLabelEngine isLocked="true">Standard</DefaultLabelEngine>
AddDefaultElevationSource
In the user interface, on the Map and Scene tab on the Options dialog box, click Ground Elevation Surface to access the corresponding setting.
true(A default elevation source is added. This is the default.)false(No elevation source is added.)
<AddDefaultElevationSource isLocked="true">true</AddDefaultElevationSource>
CustomElevationSourceXml
Use this setting if AddDefaultElevationSource is set to true and you are using a custom elevation source. In the user interface, on the Map and Scene tab on the Options dialog box, click Ground Elevation Surface > Default Elevation Source > Use custom elevation source to access the corresponding setting.
Not set (An empty string; the default elevation service of your organization is added. This is the default.)
A data connection
.xmlfile to a custom elevation source
Set the default elevation source through the application and access the location of the user configuration file from the registry key HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGISPro\Settings\UserConfigLocalRoaming. Within this user configuration file, locate the CustomElevationSourceXml setting. Paste this XML inside your administrator setting definition in the Pro.settingsConfig file.
<CustomElevationSourceXml isLocked="true">
CIMStandardDataConnection xsi:type='typens:CIMStandardDataConnection'
WorkspaceConnectionString>DATABASE=\\[LOCATION]\Elevation</
WorkspaceConnectionString><
WorkspaceFactory>Raster</
WorkspaceFactory><Dataset>dem30.img</
Dataset><DatasetType>esriDTAny</
DatasetType></CIMStandardDataConnection>
</CustomElevationSourceXml>
AreUnRegisteredDatasetsAndCsvBackwardCompatible
In the user interface, on the Map and Scene tab on the Options dialog box, click Add Layers and Tables > Query layers and text files > Use field types that are compatible with ArcGIS Pro 3.1 and earlier releases when adding query layers and text files to access the corresponding setting.
truefalse(default)
<AreUnRegisteredDatasetsAndCsvBackwardCompatible isLocked="true">false</AreUnRegisteredDatasetsAndCsvBackwardCompatible>
ManageFeatureCaching
In the user interface, on the Map and Scene tab on the Options dialog box, click Feature Cache > Manage feature cache from the Map tab to access the corresponding setting.
truefalse(default)
<ManageFeatureCaching isLocked="true">true</ManageFeatureCaching>
CheckMapsWhenDeleting
In the user interface, on the Map and Scene tab on the Options dialog box, click Layer Data Sources > When data sources are deleted: to access the corresponding setting.
None—Do not remove map layers when data sources are deleted. This is the default.Open—Remove corresponding layers in open maps when data sources are deleted.All—Remove corresponding layers in all maps when data sources are deleted.
<CheckMapsWhenDeleting isLocked="true">None</CheckMapsWhenDeleting>
CheckMapsWhenRenaming
In the user interface, on the Map and Scene tab on the Options dialog box, click Layer Data Sources > When data sources are renamed: to access the corresponding setting.
None—Do not update map layers when data sources are renamed.Open—Update layers in open maps when data sources are renamed. This is the default.All—Update layers in all maps when data sources are renamed.
<CheckMapsWhenRenaming isLocked="true">None</CheckMapsWhenRenaming>
ContentsPanePointLegendPatchSizeLimit
In the user interface, on the Map and Scene tab on the Options dialog box, click Contents Pane > Legend patch size limit to access the corresponding setting.
Possible values are values between 0 and 1000 pts. The default value is 48.
Other panes in the application may honor this setting by resizing the preview or display of legend patches to better match the Contents pane.
An example is shown below.
<ContentsPanePointLegendPatchSizeLimit isLocked="true">48</ContentsPanePointLegendPatchSizeLimit>
DefaultQueryBuilderMode
In the user interface, on the Map and Scene tab on the Options dialog box, click Query Builder > Default query builder mode to access the corresponding setting.
Designer—Sets the default mode to SQL Designer, which builds queries interactively with clauses. This is the default.Editor—Sets the default mode to SQL Editor, which creates queries directly in SQL syntax.
In ArcGIS Data Reviewer, except for the Query Attributes check, the Validation attribute rule and Run Data Checks workflows do not honor this setting.
<DefaultQueryBuilderMode isLocked="true">Designer</DefaultQueryBuilderMode>
PermitMapTips
In the user interface, on the Display tab of the Layer Properties dialog box, click Show MapTips to access the corresponding setting.
truefalse(default)
<PermitMapTips isLocked="true">false</PermitMapTips>
DisplayTheseScalesWhenZooming
In the user interface, on the Scale Properties dialog box of a map, click Only display these scales when zooming to access the corresponding setting.
truefalse(default)
<DisplayTheseScalesWhenZooming isLocked="true">false</DisplayTheseScalesWhenZooming>
AllowAssignmentOfUniqueNumericIDs
In the user interface, on the Map and Scene tab of the Options dialog box, click Layer IDs > Assign unique numeric IDs to all layers in new maps to access the corresponding setting.
truefalse(default)
<AllowAssignmentOfUniqueNumericIDs isLocked="true">false</AllowAssignmentOfUniqueNumericIDs>
