ArcGIS Data Reviewer checks
Available with Data Reviewer license.
ArcGIS Data Reviewer checks are tools that allow you to evaluate your data based on specific conditions. Some checks allow you to search for conditions, such as polygon slivers or cutbacks, while other checks allow you to search for features that have spatial relationships with each other. For example, you can find cutbacks on route features that impact measurement values in pipes or find buildings that have been mistakenly placed on water features. Once a check is configured with specific conditions, it can be used as a rule designed to meet your organization's needs.
Access a poster of the checks available in Data Reviewer
Run Data Checks workflow
The Run Data Checks tool determines a feature's quality with minimum configuration. This form of automated review is helpful when an initial assessment of data quality is required.
Consider the following when implementing automated review using the Run Data Checks tool:
  • Rules are created using tools in ArcGIS Pro.
  • Rules don't need to be saved before running the tool.
  • A read-only permission on source data is required for creating rules.
  • Validation of features is supported using ArcGIS Pro (Run Data Checks command).
  • Only features from file and mobile geodatabases are supported.
  • Errors are stored in a temporary geodatabase created during an ArcGIS Pro session. The geodatabase gets deleted once ArcGIS Pro is closed.
  • Global IDs and editor tracking are not required.
  • Error management is not available after error results are detected. Instead, attribute validation rules provide the capability to track corrections and verify errors.
Learn more about using checks for Run Data Checks workflows
Attribute rule workflows
Implementing repeatable assessment of a feature's quality is supported by checks in Attribute rule-based workflows. These include the ability to prevent the creation of poor-quality features during editing (constraint attribute rules), as well as the ability to identify poor-quality features that already exist in your database (validation attribute rules). This form of automated review is helpful when assessing multiple aspects of a feature's quality to ensure consistency across multiple data management workflows.
Consider the following when implementing automated review using Reviewer geodatabase rules:
  • Rules must be saved before running the tool.
  • Geodatabase rules enable assessment of a feature's quality during (constraint attribute rule) and after editing (validation attribute rule).
  • Features and rows are stored in geodatabase feature classes and stand-alone tables are supported.
  • Attribute rule-based workflows support the validation of feature service data shared through ArcGIS Enterprise.
  • Errors are stored in system-maintained tables along with production data.
  • Global IDs and editor tracking are required.
  • Error phase and status information are managed automatically for errors created using validation attribute rules.
Learn more about managing Reviewer rules in a geodatabase
Attribute checks
Check name
Workflow
Domain
Finds attribute values that do not comply with the coded value or range domains that are associated with an attribute field
Attribute rules
Run Data Checks
Duplicate Row
Finds features or rows that contain a set of shared attribute values.
Attribute rules
Run Data Checks
Query Attributes
Finds records based on a WHERE clause run against row attributes
Attribute rules
Run Data Checks
Regular Expression
Finds features and rows that contain text values that do not match a defined pattern
Attribute rules
Run Data Checks
Relationship
Finds rows in feature classes and stand-alone tables that violate cardinality or relationship rules defined in a relationship class
Attribute rules
Run Data Checks
Subtype
Finds features in a subtype with improper or null attribute values
Attribute rules
Run Data Checks
Table to Table Attribute
Finds features or rows that contain attribute values that meet a relationship you define and compares them to values in another feature class or stand-alone table
Attribute rules
Run Data Checks
Unique Field Value
Finds rows in feature classes and stand-alone tables that contain non-unique values in an editable field or a list of fields
Attribute rules
Run Data Checks
Event checks
Check name
Workflow
Event on Event
Finds linear referenced events that overlay other events based on a relationship you define
Attribute rules
Find Orphan Events
Finds linear referenced events that have no association with a route feature
Attribute rules
Run Data Checks
Find Event Gaps
Finds linear referenced events with gaps in the same category, route, or across multiple routes
Attribute rules
Run Data Checks
Find Event Overlaps
Finds linear referenced events that overlap with events in the same category, route, or across multiple routes
Attribute rules
Run Data Checks
Invalid Event Measures
Finds invalid measure values of events on the same route or across multiple routes
Attribute rules
Run Data Checks
Feature integrity checks
Check name
Workflow
Check Geometry
Finds features whose geometry is empty, null, or not simple, as well as features with empty envelopes
Attribute rules
Run Data Checks
Cutbacks
Finds segments where the angle between segments in a polygon or on a polyline is below a specified minimum value
Attribute rules
Run Data Checks
Duplicate Vertex
Finds vertices from the same features that are collocated or within a specified tolerance of one another
Attribute rules
Run Data Checks
Evaluate Part Count
Finds features with a part count that is within a specified range of values
Attribute rules
Run Data Checks
Evaluate Vertex Count
Finds polyline or polygon features that have a vertex count within a specified tolerance
Attribute rules
Run Data Checks
Nonlinear Segment
Finds polyline or polygon features that contain nonlinear segments, such as arcs and curves
Attribute rules
Run Data Checks
Polygon checks
Check name
Workflow
Evaluate Polygon Perimeter and Area
Finds polygon features based on the area or perimeter of the entire polygon or its individual parts or segments
Attribute rules
Run Data Checks
Find Polygons with Holes
Finds polygon features that have holes
Attribute rules
Run Data Checks
Polygon Gap is Sliver
Finds gaps between polygon features that are below a specified thinness ratio
Attribute rules
Run Data Checks
Polygon Overlap is Sliver
Finds overlaps between polygon features that are below a specified thinness ratio
Attribute rules
Run Data Checks
Polygon Sliver
Finds polygon features with a thinness ratio below a specified threshold
Attribute rules
Run Data Checks
Unclosed Polygon
Finds unclosed rings in polygon features
Attribute rules
Run Data Checks
Unnecessary Polygon Boundaries
Finds polygon features that share a common boundary and contain identical attribute values
Attribute rules
Run Data Checks
Polyline checks
Check name
Workflow
Evaluate Polyline Length
Finds polyline segments, parts, or features that have a line length within a specified tolerance
Attribute rules
Run Data Checks
Find Dangles
Finds polylines that have dangles within a specified tolerance
Attribute rules
Run Data Checks
Find Disconnected Polylines
Finds polyline features that are not connected to other features in the same or other data sources
Attribute rules
Run Data Checks
Monotonicity
Finds vertices in z-enabled or m-enabled polylines that are not strictly increasing or decreasing in value or that are trending based on specified conditions
Attribute rules
Run Data Checks
Polyline or Path Closes on Self
Finds paths or lines on polyline features that close themselves
Attribute rules
Run Data Checks
Unnecessary Nodes
Finds polyline features that share a node and have matching attribute values
Attribute rules
Run Data Checks
Spatial relationship checks
Check name
Workflow
Composite
Finds features or rows based on the result from multiple Data Reviewer checks
Attribute rules
Run Data Checks
Duplicate Feature
Finds features of the same geometry type that are collocated and share attributes
Attribute rules
Run Data Checks
Evaluate Intersection Count
Finds polyline features that spatially intersect other polyline or polygon features a specified number of times
Attribute rules
Run Data Checks
Feature on Feature
Finds features that have a specific relationship, either from two feature layers or within the same feature layer
Attribute rules
Run Data Checks
Valency
Validates relationships between point and polyline features or polyline features within the same feature class, to ensure specific patterns of polylines are connected at a point
Attribute rules
Run Data Checks
Z-value checks
Check name
Workflow
Adjacent Vertex Elevation Change
Finds features that contain an elevation (Z) change greater than a specified tolerance
Attribute rules
Run Data Checks
Different Z at Intersection
Finds intersecting polyline features with z-value differences that are larger than a specified tolerance at intersection points
Attribute rules
Run Data Checks
Evaluate Z Values
Finds features whose z-values are within the specified parameters
Attribute rules
Run Data Checks
