Unnecessary Nodes
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Summary
The Unnecessary Nodes check finds polyline features that share a node and have matching attribute values.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow
Supported
Licensing
Validation attribute rule
Yes (ArcGIS Pro 2.7 and ArcGIS Enterprise 10.9 or later)
Constraint attribute rule
Yes (ArcGIS Pro 3.2 or later)
Run Data Checks
Yes (ArcGIS Pro 3.5 or later)
Available with a Data Reviewer license
Overview
When polyline features contain pseudo nodes and identical attribution on editable fields, the shared node is often unnecessary. Pseudo nodes occur when the end node on a feature connects to another end node with no other nodes present. Features found with this check can be merged without a loss of information and can result in enhanced database performance.
Attribute Rule syntax
The following table describes the validation and constraint attribute rule parameters:
Parameter
Required
Workflow
Subtype
No
The subtype or subtypes to which the rule is applied.
Constraint
Validation
Attribute
No
A query that identifies the features to which the rule is applied.
Validation
Attributes to Ignore
No
The attribute values to ignore during evaluation. Only editable fields can be ignored.
To select all of the listed attributes, check the Select All check box. To select specific attributes, check the check box next to each attribute that you want to ignore.
Constraint
Validation
Triggers
Yes
  • Insert—Triggers the rule when a new feature is added.
  • Update—Triggers the rule when a feature is updated.
  • Delete—Triggers the rule when a feature is deleted.
Constraint
Name
Yes
A unique name for the rule.
Use this information to support data quality requirement traceability, automated reporting, and corrective workflows.
Constraint
Validation
No
A description of the error you define when a noncompliant feature is found.
Use this information to provide guidance for corrective workflows.
Constraint
Validation
Severity
No
The severity of the error assigned when a noncompliant feature is found.
This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest.
Validation
Tags
No
The tag property of the rule.
This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements.
Constraint
Validation
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter
Required
Input Feature
Yes
The input feature layer that is evaluated by the rule.
You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation.
Subtypes
No
Attribute Filter
No
No
Name
Yes
Use this information to support data quality requirement traceability.
Extent
Yes
  • Visible Extent—Evaluate the visible extent of the map.
  • Full Extent—Evaluate the full extent of the data.
Notes
Keep the following in mind when using the check:
  • M- and z-values are ignored when evaluating the geometry of input features.
  • The Validation Status attribute value of input features is ignored during evaluation. For example, input features with a validation status of 0 (No calculation required, no validation required, no error), 1 (No calculation required, no validation required, has error(s)), 4 (Calculation required, no validation required, no error), or 5 (Calculation required, no validation required, has error(s)) are still included during rule evaluation.
  • The Attribute filter parameter is limited to comparison (=, <>, >, <, >=, and <=) and logical (AND/OR, IN/NOT IN, LIKE/NOT LIKE, and IS NULL) operators.
  • The Attribute and the Attributes to Ignore filter parameters do not support the following field types: Big Integer, Date Only, Time Only, and Timestamp Offset.
  • GUID and Object ID data types are ignored during evaluation.
  • The following conditions apply when this check is authored as a Run Data Check:
    • Subtype Group Layers are not supported.
    • Multipoint error results are supported.
