Feature on Feature
Available with Data Reviewer license.
Summary
The Feature on Feature check finds features from the same or two different feature layers that share a spatial relationship and returns them as results.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow |
Supported |
Licensing |
Validation attribute rule |
Yes (ArcGIS Pro 2.5 or later) |
Available with ArcGIS Pro Standard and Data Reviewer licenses |
Constraint attribute rule |
Yes (ArcGIS Pro 2.4 or later) |
Run Data Checks |
Yes (ArcGIS Pro 3.4 or later) |
Available with a Data Reviewer license |
Legacy:
Map-based Reviewer rules are deprecated and are not available for use. It is recommended that you migrate automated review workflows to Data Reviewer capabilities available in attribute rules. Opening or saving a map document (.aprx file) at ArcGIS Pro 3.0 or later removes all the existing map rules from the document.
Overview
The Feature on Feature check identifies features that are spatially related, such as a road on a land feature or a lake surrounded by grassland. Features from the same feature class can also overlap one another and share common attribute values.
When configured as a constraint rule, an error is returned if a feature that meets the conditions defined in the parameters of the rule is created or modified.
When configured as a validation rule, an error is created for each feature that meets the conditions defined in the parameters of the rule. You can access this error in the Error Inspector pane.
Industry scenarios
This check can be used in the following scenarios:
In parcel management, the Feature on Feature check ensures that lot units in tax parcels do not overlap.
In address management, road centerline features that contain overlaps or gaps in address ranges can impact the accuracy of locators used in geocoding.
In water utility management, features connected with different values on key attributes are a common problem. For example, errors may occur when a valve is connected to a pipe but the diameters of the pipes are different, such as a 12-inch-diameter valve that connects to two 8-inch-diameter water mains.
In electrical utility management, for proper network analysis, features that are connected must be located on the endpoints of another feature. For example, analysis errors may occur when a switch feature does not split the primary conductor line that it is connected to.
When using data from ArcGIS Indoors, unit polygons such as offices, bathrooms, and break rooms must be within the horizontal and vertical bounds of their corresponding level.
Attribute Rule syntax
The following table describes the validation and constraint attribute rule parameters:
Parameter |
Required |
Description |
Workflow |
Subtype |
No |
The subtype or subtypes to which the rule is applied. |
Constraint |
Validation |
Attribute |
No |
A query that identifies the features to which the rule is applied. |
Validation |
Features to Compare |
Yes |
Input features are returned as errors based on their relationship to the features from this data source. Valid inputs are point, polyline, and polygon features. |
Constraint |
Validation |
Filter |
No |
A query that identifies the features to include in the rule, from the data source specified in the Features to Compare parameter. |
Validation |
Spatial Relationship |
Yes |
The spatial relationship to be evaluated. The options are as follows:
Constraint |
Validation |
DE-9IM String |
Conditional |
This parameter is required if the Spatial Relationship parameter is set to DE-9IM. |
Constraint |
Validation |
Horizontal Search Distance |
No |
A horizontal buffer distance used to determine the spatial relationship. This parameter is only available if the Spatial Relationship parameter is set to Intersects. |
Constraint |
Validation |
Evaluate Z |
No |
This parameter evaluates z-values by comparing two features to assess whether the spatial relationship persists in z, as well as in x and y. This parameter is currently available for specific combinations of spatial relationships and geometry types. Refer to the Evaluate Z parameter supported spatial relationships and geometry types section below for guidance on available configurations. Note:All feature classes participating in a Feature on Feature rule with Evaluate Z enabled must have the same vertical coordinate system. |
Validation |
Vertical Search Distance |
Conditional |
A subparameter of Evaluate Z that evaluates a vertical search distance above and below a feature so that an exact match of z-values between the two features is not required. This parameter is only enabled when the Evaluate Z parameter is checked.
Validation |
Attribute Relationship |
No |
After the spatial relationship is evaluated, this parameter enables the comparison of attribute values to be included in the validation. For example, it can be used to identify features that intersect and share a common attribute value. |
Validation |
Invert Relationship |
No |
After the relationship is evaluated, this parameter specifies whether the result will be used as is or inverted. For example, it can be used to identify features that do not intersect or are not within a defined distance of another feature.
Constraint |
Validation |
Triggers |
Yes |
The editing events that trigger the rule to take effect.
Constraint |
Name |
Yes |
A unique title or name for the rule. This information is used to support data quality requirement traceability, automated reporting, and corrective workflows. |
Constraint |
Validation |
Description |
No |
A description of the error you define when a noncompliant feature is found. This information is used to provide guidance for corrective workflows. |
Constraint |
Validation |
Severity |
No |
The severity of the error assigned when a noncompliant feature is found. This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest. |
Validation |
Tags |
No |
The tag property of the rule. This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements. |
Constraint |
Validation |
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter |
Required |
Description |
Input Feature |
Yes |
The input feature layer that is evaluated by the rule. Note:You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation. |
Subtypes |
No |
Attribute Filter |
No |
Yes |
Input features are returned as errors based on their relationship to the features from this data source. Note:You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation. |
Filter |
No |
Yes |
DE-9IM String |
Conditional |
Evaluate Z |
No |
This parameter evaluates z-values by comparing two features to assess if the spatial relationship persists in z, as well as in x and y. This parameter is available for specific combinations of spatial relationships and geometry types. Refer to the Evaluate Z parameter supported spatial relationships and geometry types section below for guidance on available configurations. Note:All feature classes participating in a Feature on Feature rule with Evaluate Z enabled must have the same vertical coordinate system. |
Conditional |
No |
No |
Name |
Yes |
A unique title or name for the rule. This information is used to support data quality requirement traceability. |
Extent |
Yes |
Feature class 1 |
Spatial relationship |
Feature class 2 (Features to compare) |
Point |
Touches |
Line |
Point |
Intersects |
Line |
Line |
Touches |
Point |
Line |
Intersects |
Point |
Line |
Touches |
Line |
Line |
Within |
Line |
Line |
Intersects |
Line |
Line |
Crosses |
Line |
Line |
Overlaps |
Line |
Polygon |
Within |
Polygon |
Polygon |
Intersects |
Polygon |
Polygon |
Intersects |
Point |
Point |
Intersects |
Polygon |
Line |
Within |
Polygon |
Notes
Keep the following in mind when using the check:
The data sources of the input features and Features to Compare parameter must share a common datum.
When this check is authored as an attribute (constraint) rule, support for geographic coordinate system-based datasets is limited to those using Web Mercator (WKID 3857) or WGS84 (WKID 4326).
The following conditions apply when this check is authored as an attribute (validation) rule:
Data sources for the Features to Compare parameter must include a global ID field.
The
Validation Statusattribute values of both the input features and the data sources included in the Features to Compare parameter are ignored during evaluation. For example, input features with a validation status of 0 (No calculation required, no validation required, no error), 1 (No calculation required, no validation required, has error(s)), 4 (Calculation required, no validation required, no error), or 5 (Calculation required, no validation required, has error(s)) are still included during rule evaluation.Include the data source for the Features to Compare parameter when creating map or project packages and when sharing web layers with the Validation capability enabled.
A feature’s geometry is returned instead of an error geometry when this check is configured using the Intersect spatial relationship with the Horizontal Search Distance parameter.
The Attribute, Features to Compare, and Attribute Relationship filter parameters do not support the following field types:
Big Integer,Date Only,Time Only, andTimestamp Offset.The Attribute and Filter parameters are limited to comparison (
=,<>,>,<,>=, and<=) and logical (AND/OR,IN/NOT IN,LIKE/NOT LIKE, andIS NULL) operators.DE-9IM is not supported when the Evaluate Z parameter is checked.
The following condition applies when this check is authored as a Run Data Check:
- Subtype Group Layers are not supported.
