Configure the Error Inspector pane
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Error features captured by Reviewer validation rules are stored in the error layers. Errors can be reviewed in the Error Inspector pane during quality assurance workflows.
Once a dataset has been evaluated using attribute rules, use the Error Inspector pane and Details tab to review information about each error feature.
Learn more about managing attribute rule errors
Display error life cycle
The Error Inspector pane supports the error life cycle process for errors created using Reviewer validation attribute rules. To access the status of error results from the Error Inspector pane, complete the following steps:
  1. In the Contents pane, right-click a layer containing data to be evaluated and click Add Error Layers .
    Point, polyline, polygon, and object error layers are added to the map in a new group layer named Error Layers.
  2. On the Edit tab, in the Manage Edits group, click Error Inspector .
    The Error Inspector pane appears.
  3. If the Phase and Status columns are not visible on the Error Inspector toolbar, click the menu button and click Show Status.
    If visual review is enabled, the Category column appears.
    Phase and Status columns in the Error Inspector pane
Learn more about error results and their life cycle
Filter error features
You can refine the list of errors displayed in the Error Inspector pane by applying filters. You can apply multiple filters to errors displayed in the pane. For example, you can filter errors by Phase and Severity to identify active errors that most severely impact data quality.
To filter the display of error results, complete the following steps:
  1. In the Error Inspector pane, from the Filter group, click Fields .
    Fields filter options
    The Category filter is visible once visual review has been enabled at least once in the geodatabase.
    Learn more about enabling visual review
  2. In the Fields menu, expand a filter type to display a list of its values.
    Fields filter option values
  3. Apply filter types as necessary.
  4. Click Close to close the menu and display the errors that meet the filter criteria.
Filter error features by rule name
You can use advanced rule filtering capabilities in the Error Inspector pane to further refine error results. Filtering by feature class and by rule name allows you to focus on specific error results. Multiple filters can be configured at once for more precise control over the results that appear in the Error Inspector pane.
To use advanced source filtering to view specific error results, complete the following steps:
  1. In the Error Inspector pane, in the Filter group, click Rules .
    A query appears.
    A query filter in a default state
  2. Click the Select a Source drop-down arrow and select the feature class name that you want to filter.
    Only feature classes with authored attribute rules appear in the Select a Source drop-down menu.
  3. Click the Select a Rule drop-down arrow and select the name of the rule that you want to view.
  4. Optionally, click Add Clause to apply additional source filters.
    The Error Inspector pane automatically updates to show the filtered results.
  5. Click Clear All to remove the filter.
    The Error Inspector pane reverts back to displaying all of the default error results.
Mark or clear error exceptions
Violations to reviewer rules are stored as error features. You can mark error features as exceptions or clear existing exceptions from the Error Inspector pane.
Errors marked as an exception may change the Validation Status attribute of the feature that created the error, such as the following:
  • If an error is marked as an exception, the feature's Validation Status attribute value switches to No calculation required, no validation required, no error.
  • If only one feature is marked as an exception and is associated with multiple errors from different rules, the Validation Status attribute value will remain No calculation required, no validation required, has error(s).
Features with errors marked as exceptions are still evaluated by the Validation Status attribute. For example, if a feature marked as an exception is edited after validation, the Validation Status attribute value will change from No calculation required, no validation required, no error to No calculation required, validation required, no error.
To mark or clear exceptions, complete the following steps:
  1. In the Error Inspector pane, click the numbered column for an error to select it in the data grid.
    Tip:
    You can select multiple errors in the data grid by pressing the Ctrl key while clicking numbered columns.
  2. Right-click any of the numbered columns that you selected and choose one of the following options:
    • Mark As Exception Mark as Exception—Updates the isException field of the error feature to True. The domain value for True is 1.
    • Clear Exception Clear Exception—Updates the isException field of the error feature to False. The domain value of False is 0.
The isException property for the error feature is updated.
Mark as resolved or unacceptable
Error features found using the Browse Features and Flag Missing Features visual review tools can be marked as resolved or unacceptable. To mark a visual review error as resolved or unacceptable, complete the following steps:
    Tip:
    You can select multiple errors in the data grid by pressing the Ctrl key while clicking the numbered columns that you want to select.
    • Mark As Resolved Verify—Updates the error feature's status to acceptable.
    • Mark As Unacceptable Error—Updates the error feature's status to unacceptable.
