Find Event Overlaps
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Summary
The Find Event Overlaps check finds linear-referenced events that have overlaps with events of the same category, in the same route, or across multiple routes. For example, the same categories can be two speed limit events overlapping with two different speed limit values.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow
Supported
Validation attribute rule
Yes (ArcGIS Pro 3.1 and ArcGIS Enterprise 11.1 or later)
Constraint attribute rule
No
N/A
Run Data Checks
Yes (ArcGIS Pro 3.5 or later)
Available with a Data Reviewer license
Overview
The Find Event Overlaps check identifies event overlaps that can impact analysis and asset management workflows.
Examples
The following image illustrates linear events (in red) that overlap other events in the same route and across multiple routes.
Overlapping events
Attribute Rule syntax
The following table describes the validation attribute rule parameters:
Parameter
Required
Workflow
Subtype
No
The subtype or subtypes to which the rule is applied.
Validation
Attribute
No
A query that identifies the features to which the rule is applied.
Validation
Event Properties/Route Identifier
Yes
The name of the field that contains values used to associate events to routes.
The field must be a numeric data type.
Validation
Event Properties/From Measure
Yes
The name of the field that contains the measure value that describes the starting location for a linear event feature.
For point event features, this parameter is named Measure and describes the location of the point.
Validation
Event Properties/To Measure
Yes
The name of the field that contains the measure value that describes the end location for a linear event feature.
Validation
Event Properties/Event From Date
Yes
The name of the field that contains values that define the starting date for a point or linear event feature.
The field must be a date data type.
Validation
Event Properties/Event To Date
Yes
The name of the field that contains values that define the ending date for a point or linear event feature.
Validation
Route Properties/Input Route
Yes
The input route feature to which the event is referenced.
Validation
Route Properties/Route Identifier
Yes
Validation
Route Properties/Route From Date
Yes
The name of the field that contains values that define the starting date for a route.
Validation
Route Properties/Route To Date
Yes
The name of the field that contains values that define the ending date for a route.
Validation
Measure tolerance
No
Optional value used when finding events that overlap other events. Events within this tolerance are considered valid.
The linear referencing system m-tolerance is used by default.
Validation
Name
Yes
A unique name for the rule.
Use this information to support data quality requirement traceability, automated reporting, and corrective workflows.
Validation
No
A description of the error you define when a noncompliant feature is found.
Use this information to provide guidance for corrective workflows.
Validation
Severity
No
The severity of the error assigned when a noncompliant feature is found.
This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest.
Validation
Tags
No
The tag property of the rule.
This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements.
Validation
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter
Required
Input Feature
Yes
The input feature layer that is evaluated by the rule.
You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation.
Subtypes
No
Attribute Filter
No
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Measure tolerance
No
Name
Yes
Use this information to support data quality requirement traceability.
Extent
Yes
  • Visible Extent—Evaluate the visible extent of the map.
  • Full Extent—Evaluate the full extent of the data.
Notes
Keep the following in mind when using the check:
  • MGDBs and FGDBs are supported.
  • This check supports validation of events stored in line feature classes.
  • This check supports validation of events that are stored in a geodatabase and registered with the ArcGIS Roads and Highways or ArcGIS Pipeline Referencing linear referencing system (LRS).
  • Route features must be m-enabled and registered with the Roads and Highways or Pipeline Referencing LRS.
  • A route identifier field (numeric data type) is required for all route and event features.
  • An attribute index on the route identifier field accelerates the dynamic segmentation process.
  • Events associated with nonmonotonic route features are not evaluated by this check. Nonmonotonic routes are routes that contain measure values that are either continuous or do not strictly increase or decrease in value.
    The Monotonicity check is used to find nonmonotonic routes that require correction.
  • The Attribute filter parameter is limited to comparison (=, <>, >, <, >=, and <=) and logical (AND/OR, IN/NOT IN, LIKE/NOT LIKE, and IS NULL) operators.
  • The Attribute filter parameter does not support the following field types: Big Integer, Date Only, Time Only, and Timestamp Offset. If selected, the row header is marked in red and does not allow the rule to be saved.
  • Setting the default query builder mode is not supported.
  • The following condition applies when this check is authored as a Run Data Check:
    • Subtype Group Layers are not supported.
