Adjacent Vertex Elevation Change
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Summary
The Adjacent Vertex Elevation Change check searches for polyline and polygon features with vertices that have elevation differences (z-values) greater than a specified tolerance. The tolerance value helps identify significant gaps between feature elevations.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow
Supported
Licensing
Validation attribute rule
Yes (ArcGIS Pro 2.9 and ArcGIS Enterprise 10.9.1 or later)
Constraint attribute rule
No
N/A
Run Data Checks
Yes (ArcGIS Pro 3.5 or later)
Available with a Data Reviewer license
Overview
When performing quality control checks on your database, you can search for features with significant differences in elevation represented by the z-value. For example, within a contour feature class, the z-value for a given contour should be constant for all vertices. Occasionally, there are outlying vertices with different z-values.
The Adjacent Vertex Elevation Change check returns vertices for polylines or polygon features with an elevation (Z) change greater than the specified tolerance. The tolerance value helps identify gaps between feature elevations. You can run the check on an entire feature class, subtype, or set of features selected using an SQL query. The check features that fall outside of the specified tolerance, or have a difference that is greater than the value specified, are returned as errors. These features can then be written to the Reviewer table for further inspection and correction.
Attribute rule syntax
The following table describes the validation attribute rule parameters:
Parameter
Required
Workflow
Subtype
No
The subtype or subtypes to which the rule is applied.
Validation
Attribute
No
A query that identifies the features to which the rule is applied.
Validation
Elevation Difference Tolerance
Yes
The minimum value allowed for elevations between vertices. The value must be greater than the geodatabase z-tolerance.
Map units include feet, U.S. feet and meters, kilometers, decimal degrees, and decimeters.
Validation
Name
Yes
A unique name for the rule.
Use this information to support data quality requirement traceability, automated reporting, and corrective workflows.
Validation
No
A description of the error you define when a noncompliant feature is found.
This information is used to provide guidance for corrective workflows.
Validation
Severity
Yes
The severity of the error assigned when a noncompliant feature is found.
This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest.
Validation
Tags
No
The tag property of the rule.
This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements.
Validation
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter
Required
Input Feature
Yes
The input feature layer that is evaluated by the rule.
You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation.
Subtypes
No
Attribute Filter
No
Yes
Name
Yes
Use this information to support data quality requirement traceability.
Extent
Yes
  • Visible Extent—Evaluate the visible extent of the map.
  • Full Extent—Evaluate the full extent of the data.
Notes
Keep the following in mind when using the check:
  • This check supports z-enabled polyline and polygon features.
  • A vertical coordinate system must be defined for the feature classes that you want to use with this check.
  • The evaluation ignores the Validation Status attribute value of input features. For example, input features with a validation status of 0 (No calculation required, no validation required, no error), 1 (No calculation required, no validation required, has error(s)), 4 (Calculation required, no validation required, no error), or 5 (Calculation required, no validation required, has error(s)) are still included during rule evaluation.
  • The Attribute filter parameter is limited to comparison (=, <>, >, <, >=, and <=) and logical (AND/OR, IN/NOT IN, LIKE/NOT LIKE, and IS NULL) operators.
  • The Attribute filter parameter does not support the following field types: Big Integer, Date Only, Time Only, and Timestamp Offset. If selected, the row header is marked in red and does not allow the rule to be saved.
  • The following conditions apply when this check is authored as a Run Data Check:
    • Subtype Group Layers are not supported.
    • Multipoint error results are supported.
