Unnecessary Polygon Boundaries
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Summary
The Unnecessary Polygon Boundaries check finds polygon features that share a common boundary and contain identical attribute values.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow |
Supported |
Licensing |
Validation attribute rule |
Yes (ArcGIS Pro 2.7 and ArcGIS Enterprise 10.9 or later) |
Available with ArcGIS Pro Standard and Data Reviewer licenses |
Constraint attribute rule |
Yes (ArcGIS Pro 3.2 or later) |
Run Data Checks |
Yes (ArcGIS Pro 3.5 or later) |
Available with a Data Reviewer license |
Overview
When polygon features share a common boundary and contain identical attribute values on editable fields, the shared boundary is often unnecessary and is captured as an error. Features found with this check can be merged without a loss of information and can result in enhanced database performance.
In the following example, a polygon that shares its boundaries with multiple polygons produces either one or multiple error results:
Attribute Rule syntax
The following table describes the validation and constraint attribute rule parameters:
Parameter |
Required |
Description |
Workflow |
Subtype |
No |
The subtype or subtypes to which the rule is applied. |
Validation |
Constraint |
Attribute |
No |
A query that identifies the features to which the rule is applied. |
Validation |
Attributes to Ignore |
No |
The attribute values to ignore during evaluation. Only editable fields can be ignored. To select all of the listed attributes, check the Select All check box. To select specific attributes, check the check box next to each attribute that you want to ignore. |
Validation |
Constraint |
Triggers |
Yes |
The editing events that trigger the rule to take effect.
Constraint |
Name |
Yes |
A unique name for the rule. Use this information to support data quality requirement traceability, automated reporting, and corrective workflows. |
Validation |
Constraint |
Description |
No |
A description of the error you define when a noncompliant feature is found. Use this information to provide guidance for corrective workflows. |
Validation |
Constraint |
Severity |
No |
The severity of the error assigned when a noncompliant feature is found. This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest. |
Validation |
Tags |
No |
The tag property of the rule. This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements. |
Validation |
Constraint |
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter |
Required |
Description |
Input Feature |
Yes |
The input feature layer that is evaluated by the rule. Note:You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation. |
Subtypes |
No |
Attribute Filter |
No |
No |
Name |
Yes |
A unique name for the rule. Use this information to support data quality requirement traceability. |
Extent |
Yes |
Notes
Keep the following in mind when using the check:
The
Validation Statusattribute value of input features is ignored during evaluation. For example, input features with a validation status of 0 (No calculation required, no validation required, no error), 1 (No calculation required, no validation required, has error(s)), 4 (Calculation required, no validation required, no error), or 5 (Calculation required, no validation required, has error(s)) are still included during rule evaluation.The Attribute filter parameter is limited to comparison (
=,<>,>,<,>=, and<=) and logical (AND/OR,IN/NOT IN,LIKE/NOT LIKE, andIS NULL) operators.GUID and Global ID data types are ignored during evaluation.
The Attribute and the Attributes to Ignore filter parameters do not support the following field types:
Big Integer,Date Only,Time Only, andTimestamp Offset.When this check is authored as a Run Data Check, Subtype Group Layers are not supported.
