Polygon Overlap is Sliver
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Summary
Sliver polygons are usually small polygons resulting from overlay operations such as Intersect or Union. Sliver polygons typically have an area that is much smaller than the perimeter. The Polygon Overlap is Sliver check finds overlaps between polygon features that are below a specified thinness ratio.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow |
Supported |
Licensing |
Validation attribute rule |
Yes (ArcGIS Pro 2.9 and ArcGIS Enterprise 10.9.1 or later) |
Available with ArcGIS Pro Standard and Data Reviewer licenses |
Constraint attribute rule |
No |
N/A |
Run Data Checks |
Yes (ArcGIS Pro 3.5 or later) |
Available with a Data Reviewer license |
Overview
The Polygon Overlap is Sliver check finds overlaps between polygon features that are slivers based on their shape and, optionally, size. Sliver overlaps between polygon features often result from creating polygon features without proper snapping settings or from editing shared boundaries without a topology.
When configured as a validation rule, an error is created for each feature that shares a boundary with a sliver overlap.
Attribute Rule syntax
The following table describes the validation attribute rule parameters:
Parameter |
Required |
Description |
Workflow |
Subtype |
No |
The subtype or subtypes to which the rule is applied. |
Validation |
Attribute |
No |
A query that identifies the features to which the rule is applied. |
Validation |
Features to Compare |
Yes |
Input features are returned as errors based on their relationship to the features from this data source. Only polygon features are supported. |
Validation |
Filter |
No |
A query that identifies the features to include in the rule, from the data source specified in the Features to Compare parameter. |
Validation |
Thinness Ratio |
Yes |
The thinness ratio (T) between the overlap area (A) and its perimeter (P) is calculated using the following equation: \(T \space = \space 4π(A/P²)\) A thinness ratio of 1 is a perfect circle, and a thinness ratio of 0 is a line. Overlaps between polygons with a thinness ratio less than this value are considered errors. |
Validation |
Maximum Area |
No |
The maximum overlap area that is considered a sliver overlap. Overlaps between polygons that are below the thinness ratio and equal to or less than this value are considered errors. The default unit of measure is the unit of measure used by the input data source's horizontal spatial reference. |
Validation |
Name |
Yes |
A unique name for the rule. Use this information to support data quality requirement traceability, automated reporting, and corrective workflows. |
Validation |
Description |
No |
A description of the error you define when a noncompliant feature is found. Use this information to provide guidance for corrective workflows. |
Validation |
Severity |
No |
The severity of the error assigned when a noncompliant feature is found. This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest. |
Validation |
Tags |
No |
The tag property of the rule. This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements. |
Validation |
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter |
Required |
Description |
Input Feature |
Yes |
The input feature layer that is evaluated by the rule. Note:You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation. |
Subtypes |
No |
Attribute Filter |
No |
Yes |
Input features are returned as errors based on their relationship to the features from this data source. Only polygon features are supported. Note:You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation. |
Filter |
No |
Thinness Ratio |
Yes |
Maximum Area |
No |
Name |
Yes |
A unique name for the rule. Use this information to support data quality requirement traceability. |
Extent |
Yes |
Notes
Keep the following in mind when using the check:
The data sources of the input features and Features to Compare parameter must share a common datum.
The
Validation Statusattribute values of both the input features and the data sources included in the Features to Compare parameter are ignored during evaluation. For example, input features with a validation status of 0 (No calculation required, no validation required, no error), 1 (No calculation required, no validation required, has error(s)), 4 (Calculation required, no validation required, no error), or 5 (Calculation required, no validation required, has error(s)) are still included during rule evaluation.The Attribute and Filter parameters are limited to comparison (
=,<>,>,<,>=, and<=) and logical (AND/OR,IN/NOT IN,LIKE/NOT LIKE, andIS NULL) operators.Data sources for the Features to Compare parameter must include a global ID field.
Errors are returned for overlaps that are greater than the x,y tolerance of the spatial reference.
Include the data source for the Features to Compare parameter when creating map or project packages and when sharing web layers with the Validation capability enabled.
The Attribute and the Features to Compare filter parameters do not support the following field types:
Big Integer,Date Only,Time Only, andTimestamp Offset. If selected, the row header is marked in red and does not allow the rule to be saved.The following condition applies when this check is authored as a Run Data Check:
- Subtype Group Layers are not supported.
