Regular Expression
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Summary
The Regular Expression check searches for text strings listed for each string field in a feature class or table and returns strings that don't match the specified format or values.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow
Supported
Licensing
Validation attribute rule
Yes (ArcGIS Pro 2.9 and ArcGIS Enterprise 10.9.1 or later)
Constraint attribute rule
No
N/A
Run Data Checks
Yes (ArcGIS Pro 3.5 or later)
Available with a Data Reviewer license
Overview
String fields use alphanumeric strings as their values. They include fields that contain the feature's name, measurements (height, length, width, and area), z-values, and metadata such as a feature's creation date.
When a string is found that does not match the format or values specified, the table row is returned as an error. For example, to find records that have an incorrect Social Security number (SSN) format, you can type \b[0-9][0-9][0-9]-[0-9][0-9]-[0-9][0-9][0-9][0-9]\b in the SSN field. The check returns features or rows that have incorrect SSN field values, such as 123456789, 123-ab-4567, 1123-34-12345, or 123-4567.
When you are searching multiple fields, you must create multiple expressions. With multiple expressions, one result is returned for one or more fields that do not match the corresponding expressions. For example, if you choose two string fields and only one matches your expression, a result is returned referencing the one field that does not match. If neither field matches the two expressions, one result is returned for the two unmatched expressions.
You can run the Regular Expression check on an entire feature class, a subtype, or a set of features selected using an SQL query.
Regular Expression checks that were exported from an ArcGIS Pro version before ArcGIS Pro 3.1 must be re-exported with ArcGIS Pro 3.1 or later to accommodate import changes.
Attribute Rule syntax
The following table describes the validation attribute rule parameters:
Parameter
Required
Workflow
Subtype
No
The subtype or subtypes to which the rule is applied.
Validation
Attribute
No
A query that identifies the features to which the rule is applied.
Validation
Search Goal
Yes
The attribute fields and the regular expression conditions that are evaluated by the rule.
Validation
Name
Yes
A unique name for the rule.
Use this information to support data quality requirement traceability, automated reporting, and corrective workflows.
Validation
No
A description of the error you define when a noncompliant feature is found.
Use this information to provide guidance for corrective workflows.
Validation
Severity
Yes
The severity of the error assigned when a noncompliant feature is found.
This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest.
Validation
Tags
No
The tag property of the rule.
This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements.
Validation
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter
Required
Input Feature
Yes
The input feature layer that is evaluated by the rule.
You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation.
Subtypes
No
Attribute Filter
No
Search Goal
Yes
Name
Yes
A unique title or name for the rule.
Extent
Yes
  • Visible Extent—Evaluate the visible extent of the map.
  • Full Extent—Evaluate the full extent of the data.
Notes
Keep the following in mind when using the check:
  • This check only appears in the Ready to Use Rules gallery when string fields that are not system generated are present in the feature class or table.
  • You can author this check for read-only string fields.
  • Features with null or invalid geometries are not evaluated by this check. Use the Check Geometry check to find invalid geometry features and correct them before using this check.
  • Only input features with a validation status of 2 (No calculation required, validation required, no error), 3 (No calculation required, validation required, has error(s)), 6 (Calculation required, validation required, no error), or 7 (Calculation required, validation required, has error(s)) are considered during rule evaluation.
  • The Attribute filter parameter is limited to comparison (=, <>, >, <, >=, and <=) and logical (AND/OR, IN/NOT IN, LIKE/NOT LIKE, and IS NULL) operators.
  • The Attribute filter parameter does not support the following field types: Big Integer, Date Only, Time Only, and Timestamp Offset. If selected, the row header is marked in red and does not allow the rule to be saved.
  • The following condition applies when this check is authored as a Run Data Check:
    • Subtype Group Layers are not supported.
