Check Geometry
Available with Data Reviewer license.
Summary
The Check Geometry check finds features that contain invalid geometry. This includes features that contain null or empty geometries or empty envelopes, and they may include geometries that are not simple.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow |
Supported |
Licensing |
Validation attribute rule |
Yes (ArcGIS Pro 3.0 and ArcGIS Enterprise 11.0 or later) |
Available with ArcGIS Pro Standard and Data Reviewer licenses |
Constraint attribute rule |
No |
N/A |
Run Data Checks |
Yes (ArcGIS Pro 3.4 or later) |
Available with a Data Reviewer license |
Legacy:
Map-based Reviewer rules are deprecated and are not available for use. It is recommended that you migrate automated review workflows to Data Reviewer capabilities available in attribute rules. Opening or saving a map document (.aprx file) at ArcGIS Pro 3.0 or later removes all the existing map rules from the document.
Overview
The creation of an invalid geometry is caused by a variety of processes, including loading and clipping data, especially when using shapefiles generated by third-party applications. Geometry that is considered invalid meets one of the following conditions:
Empty—The geometry of a feature has zero points and does not contain geometric information, represented by
SHAPE_LENandSHAPE_AREAfields, beyond its original initialization state. Empty geometries can be introduced when data is created or edited programmatically and when invalid data is imported into your geographic information system.Note:
The following are examples of how geometry information is stored for point, line, and polygon features:
A point geometry type contains a point as its geometry information.
A line or polyline geometry type contains a line segment or multiple line segments as its geometry information and is represented by points.
A polygon geometry type contains rings, formed by line segments, as its geometry information and is represented by points.
Has an empty envelope—A feature's envelope, or bounding rectangle, does not have any geometric information. This condition is similar to the empty geometry scenario.
Nothing—A feature has a NULL value in the
SHAPEfield. This type of error is returned when the check is unable to retrieve geometry information for a feature.Not simple—This type of error is returned when any of the following conditions are true:
Ring orientation is incorrect (applicable only to polygon features)—A polygon that does not self-intersect, but its rings are not oriented correctly—outer rings, clockwise or inner rings, counterclockwise.
Segment orientation is incorrect—Individual segments are not consistently oriented. The to point of segment
ishould be coincident on the from point of segmenti+1.Contains short segments—Some segments are shorter than allowed by the system units of the spatial reference associated with the geometry.
Contains self-intersecting rings (applicable only to polygon features)—A polygon must not intersect itself.
Contains self-intersecting paths (applicable only to polyline features)—A polyline must not intersect itself.
Contains unclosed rings (applicable only to polygon features)—The last vertex in a ring must be coincident with the first vertex in the ring.
Contains mismatched attributes—The z- or m-coordinate of a line segment's endpoint does not match the z- or m-coordinate of the coincident endpoint on the next segment.
Contains discontinuous parts—One of the geometry's parts is composed of disconnected or discontinuous parts.
Empty z-values (applicable to z-enabled features)—The geometry has one or more vertices with an empty z-value (NaN, for example).
Attribute Rule syntax
The following table describes the validation attribute rule parameters:
Parameter |
Required |
Description |
Workflow |
Subtype |
No |
The subtype or subtypes to which the rule is applied. |
Validation |
Attribute |
No |
A query that identifies the features to which the rule is applied. |
Validation |
Name |
Yes |
A unique name for the rule. Use this information to support data quality requirement traceability, automated reporting, and corrective workflows. |
Validation |
Description |
No |
A description of the error you define when a noncompliant feature is found. Use this information to provide guidance for corrective workflows. |
Validation |
Severity |
No |
The severity of the error assigned when a noncompliant feature is found. This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest. |
Validation |
Tags |
No |
The tag property of the rule. This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements. |
Validation |
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter |
Required |
Description |
Input Feature |
Yes |
The input feature layer that is evaluated by the rule. Note:You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation. |
Subtypes |
No |
Attribute Filter |
No |
Name |
Yes |
A unique name for the rule. Use this information to support data quality requirement traceability. |
Extent |
Yes |
Notes
Keep the following in mind when using the check:
Error results created for features that contain an invalid geometry may not be usable in a map due to the type of geometry error.
Learn more about repairing geometry and replacing feature geometry.
Any features that contain empty geometries or no geometries are automatically detected as errors, regardless of whether they are selected or in the active map extent.
The Attribute filter parameter does not support the following field types:
Big Integer,Date Only,Time Only, andTimestamp Offset. If selected, the row header is marked in red and does not allow the rule to be saved.The following condition applies when this check is authored as a Run Data Check:
- Subtype Group Layers are not supported.
