Repair Geometry (Data Management Tools)
Summary
Inspects features for geometry problems and repairs them. If a problem is found, a repair will be performed, and a one-line description will identify the feature, as well as the geometry problem that was repaired.
This tool uses the same logic as the Check Geometry tool to repair geometry problems.
Learn more about checking and repairing geometries
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • Valid input formats are shapefiles, and feature classes stored in a file geodatabase, enterprise database, enterprise geodatabase, GeoPackage, or SpatiaLite database. Mobile geodatabase is not supported. For feature classes stored in an enterprise database or enterprise geodatabase, the following spatial types are supported:
    • Microsoft SQL Server—Geometry and Geography
    • PostgreSQL—PostGIS, Geometry, and Geography
    • Oracle—SDO_Geometry
    • SAP HANA—ST_Geometry
    License:
    A Desktop Standard or Desktop Advanced license is required if the input is in an enterprise database or enterprise geodatabase.
  • Feature classes that are stored in an enterprise geodatabase and registered as versioned are not supported.
  • The Enable Undo toggle button is not valid for inputs from an enterprise geodatabase.
  • Below is the list of geometry problems and the corresponding repair that will be performed by the tool:
    • Null geometry—The record will be deleted from the feature class. To keep records with null geometry, uncheck the Delete Features with Null Geometry parameter.
    • Short segment—The geometry's short segment will be deleted.
    • Incorrect ring ordering—The geometry will be updated with the correct ring ordering.
    • Incorrect segment orientation—The geometry will be updated with the correct segment orientation.
    • Self intersections—The areas of overlap in a polygon will be dissolved.
    • Unclosed rings—The unclosed rings will be closed by connecting the end points of the rings.
    • Empty parts—The parts that are null or empty will be deleted.
    • Duplicate vertex—One of the vertices will be deleted.
    • Mismatched attributes—The z- or m-coordinate will be updated to match.
    • Discontinuous parts—Multiple parts will be created from the existing discontinuous part.
    • Empty Z values—The z-value will be set to 0.
    • Bad envelope—The feature's envelope will be updated to be correct.
    • Bad dataset extent—The feature class extent will be updated to be correct.
    Below is the list of geometry problems that may occur from data stored in an enterprise geodatabase and the corresponding repair (if one exists) that will be performed by the tool:
    • NEEDS_REORDERING—The shape will be reordered and duplicate points will be removed.
    • SE_INVALID_ENTITY_TYPE—The entity type will not be repaired (the feature must be deleted).
    • SE_SHAPE_INTEGRITY_ERROR—The shape may not be repaired.
    • SE_INVALID_SHAPE_OBJECT—The shape object may not be repaired.
    • SE_COORD_OUT_OF_BOUNDS—The coordinate will not be repaired.
    • SE_POLY_SHELLS_OVERLAP—Overlapping shells will be merged.
    • SE_TOO_FEW_POINTS—The points will not be repaired.
    • SE_INVALID_PART_SEPARATOR—The part separator may not be repaired.
    • SE_INVALID_POLYGON_CLOSURE—Unclosed shells will be discarded (the resulting polygon may be left empty).
    • SE_INVALID_OUTER_SHELL—An attempt to repair the feature's outer shells will be made; shells may be discarded in the process.
    • SE_ZERO_AREA_POLYGON—The polygon will be converted to an empty shape.
    • SE_POLYGON_HAS_VERTICAL_LINE—The vertical line will be removed (the shape may be converted to 2D).
    • SE_OUTER_SHELLS_OVERLAP—Overlapping parts will be merged.
    • SE_SELF_INTERSECTING—Intersection points will be added as needed.
    Some problems associated with data stored in an enterprise database may not be repairable with ArcGIS tools.
  • After performing a repair, the tool will reevaluate the resulting geometry and if another problem is found, the relevant repair will be performed for that problem. For example, the result of repairing a geometry with the Incorrect ring ordering problem may be a geometry with the Null geometry problem.
  • The Esri geometry validation method option ensures that geometry is topologically correct using the Esri Simplify method. Only the Esri validation is available for data stored in an enterprise geodatabase.
  • The OGC geometry validation method option ensures that geometry complies with the Open Geospatial Consortium (OGC) specification as defined in OpenGIS Implementation Standard for Geographic information – simple feature access – Part 1: common architecture.
  • After a feature's geometry is repaired using the OGC option, any subsequent edit or modification may cause the geometry to no longer comply with the OGC specification.
    After feature modification, run the Check Geometry tool to check for new geometry issues. If necessary, rerun the Repair Geometry tool.
  • Geometry that is validated or repaired using the OGC option will be valid for the Esri option. To learn more about both validation methods, see What is a simple polygon.
Parameters
Label Explanation Data type
Input Features
The feature class or layer that will be processed.
Feature services are not supported.
License:
Feature Layer
(Optional)
Specifies whether features with null geometries will be deleted.
Only the checked option is valid for inputs from an enterprise database, enterprise geodatabase, GeoPackage, or SpatiaLite database.
  • Checked—Features with null geometry will be deleted from the input. This is the default.
  • Unchecked—Features with null geometry will not be deleted from the input.
Boolean
Validation Method
(Optional)
Specifies the geometry validation method that will be used to identify geometry problems.
  • Esri—The Esri geometry validation method will be used. This is the default.
  • OGC—The OGC geometry validation method will be used.
String
Derived output
Repaired Input Features
The updated input features.
Feature Layer
Environments
Current Workspace, Extent, Parallel Processing Factor
Special cases
If the environment is not set (the default) or is set to 0, parallel processing will be disabled. If set to 100, the tool will attempt to distribute the work to all the logical cores on the machine. Specifying a factor between 1 and 99 will cause the tool to identify the percentage of logical cores to use by applying the formula (Parallel Processing Factor / 100 * Logical Cores) rounded up to the nearest integer. If the result of this formula is 0 or 1, parallel processing will not be enabled.
Licensing information
  • Basic: Limited
    Some parameters are limited by license level.
  • Standard: Yes
  • Advanced: Yes
