An overview of the Features toolset
The Features toolset contains tools to create and manage feature-based GIS data, transform features from one geometry type to another, find and correct issues with feature geometry, and record feature geometry measurements and coordinates as attributes.
Tool |
Description |
Adds the fields |
Modifies z-values of 3D features. |
Creates a feature class containing geodetic or planar line features from the values in an x-coordinate field, y-coordinate field, bearing field, and distance field of a table. |
Adds information to a feature's attribute fields representing the spatial or geometric characteristics and location of each feature, such as length or area and x-, y-, z-coordinates, and m-values. |
Generates a report of geometry problems in a feature class. |
Copies features from the input feature class or layer to a new feature class. |
Deletes all or the selected subset of features from the input. |
Subdivides a feature into smaller features based on a specified vertex limit. This tool is intended as a way to subdivide extremely large features that cause issues with drawing, analysis, editing, and/or performance but are difficult to split up with standard editing and geoprocessing tools. This tool should not be used in any cases other than those where tools are failing to complete successfully due to the size of features. |
Creates a feature class containing polygons, each of which represents the envelope of an input feature. |
Creates a feature class containing lines generated by converting polygon boundaries to lines, or splitting line, polygon, or both features at their intersections. |
Creates a feature class containing points generated from the centroids of the input features or placed within the input features. |
Creates a feature class containing polygons generated from areas enclosed by input line or polygon features or from individual enclosed lines. |
Creates a feature class containing points generated from specified vertices or locations of the input features. |
Creates new features by replacing the segments of the input features with densified approximations of geodesic segments. The following types of geodesic segments can be constructed: geodesic, great elliptic, loxodrome, and normal section. |
Creates a feature class containing polygons which represent a specified minimum bounding geometry enclosing each input feature or each group of input features. |
Creates a feature class of singlepart features by separating multipart input features. |
Creates line features from points. |
Creates a line feature class converted from polygon boundaries. You can set the tool parameters so shared segments and their neighboring polygon feature IDs will be analyzed. Alternatively, you can set the tool parameters so an enclosed line feature will be created for each input polygon. |
Inspects features for geometry problems and repairs them. If a problem is found, a repair will be performed, and a one-line description will identify the feature, as well as the geometry problem that was repaired. |
Splits line features based on intersection or proximity to point features. |
Creates a polyline feature class by splitting input lines or polygons at their vertices. |
Divides polygon features into a number of equal areas or parts. |
Creates a feature class containing geodetic or planar ellipses from the values in an x-coordinate field, y-coordinate field, major axis and minor axis fields, and azimuth field of a table. |
Aggregates line features that have coincident endpoints and, optionally, common attribute values. |
Creates a point feature class based on x-, y-, and z-coordinates from a table. |
Creates a feature class containing geodetic or planar line features from the values in a start x-coordinate field, start y-coordinate field, end x-coordinate field, and end y-coordinate field of a table. |
