Feature To Polygon (Data Management Tools)
Summary
Creates a feature class containing polygons generated from areas enclosed by input line or polygon features or from individual enclosed lines.
Illustration
Feature To Polygon tool illustration
Usage
  • Where one or more input features form a closed area, a new polygon feature will be constructed and written to the output feature class. The output attributes will vary depending on the Preserve attributes parameter value and the Label Features parameter value.
  • When multiple feature classes or layers are specified in the list of input features, the order of the entries in the list does not affect the output feature type, but the spatial reference of the top entry on the tool dialog box (the first entry in Python) in the list will be used during processing and set to the output.
  • Parametric (true) curves in the input features will remain true curves in the output polygons, even if they are split. This does not apply to shapefile data.
  • Note:
    It is recommended that you do not use the Preserve attributes parameter, as it is no longer supported and does not work. It will remain, however, for backward compatibility of scripts and models. While the output attribute schema and field values for certain input combinations may be produced as described below, most of them are unintended.
    If the Preserve attributes parameter is checked, the output attribute schema and field values will depend on whether the label features (points) are provided in the following ways:
    • If no Label Features parameter values are provided, the attribute schema (field names and properties, not field values) from each input entry will be maintained in the output in the order they appear in the input list. A new field, FID_xxx, in which xxx is the source feature class name of a particular input entry, will be added to the output for each input entry and set to the value of -1. All other fields will have zero or null values.
    • If a Label Features parameter value is provided, no input attribute schemas will be maintained in the output feature class; only the attributes of the label features will be included in the output feature class. If an output polygon contains a label feature, it will have field values from that label feature. If an output polygon contains more than one label feature, it will have field values from one of them; otherwise, it will have zero or null field values.
  • If the Preserve attributes parameter is unchecked, the input attribute schemas will be written to the output; however, the attribute values will be empty. If you do not want attributes in the output polygon feature class, supply a point feature class that has no attributes for the Label Features parameter.
  • The Polygon Construction Source parameter supports the following options, which determine how a polygon will be constructed:
    • Per enclosed area—A polygon will be constructed where one or more input features form an enclosed area. This is the default and it is supported by Standard and higher licenses.
    • Per enclosed line—A polygon will be constructed from an enclosed line (only line features will be accepted as input). If a line does not form an enclosed shape, i.e. its start and end points are more than the feature's XY Tolerance apart, that line will be skipped. When more than 10 features are skipped, a text file will be written out to store all skipped records for inspection. All input attributes will be carried over to the output. This option is supported by Basic and higher licenses and does not support Label Features.
  • When input polygon features are broken into smaller output polygon features, you can use the Identity tool to transfer attributes from the input polygon features to the resulting polygon features.
  • For better performance and scalability, this tool uses a tiling process to handle very large datasets. For details, see Tiled processing of large datasets.
Parameters
Label Explanation Data type
Input Features
The input features, which can be line, polygon, or both.
Feature Layer
Output Feature Class
The output polygon feature class.
Feature Class
XY Tolerance
(Optional)
The minimum distance separating all feature coordinates, and the distance a coordinate can move in x, y, or both directions during spatial computation. The default is 0.001 meters or its equivalent in feature units.
Caution:
Changing this parameter's value may cause failure or unexpected results. It is recommended that you do not modify this parameter. It has been removed from view on the tool dialog box. By default, the input feature class's spatial reference x,y tolerance property is used.
Linear Unit
Preserve attributes
(Optional)
This parameter is no longer supported. The parameter remains for backward compatibility of scripts and models. See the Usage section for more information.
Boolean
Label Features
(Optional)
The optional input point features that contain the attributes to be transferred to the output polygon features.
Feature Layer
(Optional)
Specifies the source criteria for a polygon to be created.
  • Per enclosed area—A polygon will be created where an enclosed area is found. This is the default. This option requires Standard or higher license.
  • Per enclosed line—A polygon will be created where an enclosed line is found. This option is available at Basic or higher license.
String
Environments
Current Workspace, Scratch Workspace, Default Output Z Value, M Resolution, M Tolerance, Output M Domain, Output Z Domain, Output Coordinate System, Extent, Output has M values, Output has Z values, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance
Licensing information
  • Basic: Limited
  • Standard: Yes
  • Advanced: Yes
