Output has Z Values (Environment setting)
Tools that honor the Output has Z Values environment will control whether the output geodataset will store z-values.
Usage notes
  • As each feature is written to the output feature class, each vertex that does not already have a z-value will be assigned the value in the Default Output Z Value environment. If the Default Output Z Value environment is not set, a value of 0 (zero) will be set.
Dialog syntax
  • Same As Input—If the input has z-values, the output will have z-values. If it does not have z-values, the output will not have z-values. This is the default.
  • Enabled—The output will have z-values.
  • Disabled—The output will not have z-values.
Python syntax
arcpy.env.outputZFlag = output_z_flag
Name Explanation
output_z_flag
Specifies whether an output geodataset will have z-values.
  • Same As Input—If the input has z-values, the output will have z-values. If the input does not have z-values, the output will not have z-values. This is the default.
Scripting syntax
import arcpy
# Set the outputZFlag environment to Enabled
arcpy.env.outputZFlag = "Enabled"
