Output has M Values (Environment setting)
Tools that honor the Output has M Values environment will control whether the output geodataset will store m-values.
Usage notes
  • Feature vertices that do not have an m-value will be assigned a value of NaN (Not a Number).
  • For shapefiles, storage of m- and z-values is closely connected; if the output has z-values, then regardless of this environment setting, the output will also have m-values.
Dialog syntax
  • Same as Input—If the input has m-values, the output will also have m-values. If the input does not have m-values, the output will not have m-values. This is the default value.
  • Enabled—The output will have m-values.
  • Disabled—The output will not have m-values.
Python syntax
arcpy.env.outputMFlag = output_m_flag
Name Explanation
output_m_flag
Specifies whether the output geodataaset will store m-values.
  • Same As Input—If the input has m-values, the output will have m-values. If the input does not have m-values, the output will not have m-values. This is the default.
Scripting syntax
import arcpy
# Set the outputMFlag environment to Enabled
arcpy.env.outputMFlag = "Enabled"
