Adjust 3D Z (Data Management Tools)
Summary
Modifies z-values of 3D features.
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • Consider inverting z-values of bathymetry and other subsurface measurements that use positive values to denote depth.
  • Use the Convert From Units and Convert To Units parameters to convert z-values from one common unit of measure to another.
Parameters
Label Explanation Data type
Input Features
The 3D features with the z-values that will be modified.
Feature Layer
Reverse Sign of Z Values
(Optional)
Specifies whether features will be inverted along the z-axis.
  • Reverse Z Orientation—The sign of z-values will be inverted causing the feature to flip upside down.
  • Maintain Z Orientation—The sign of z-values will not be inverted; it will be maintained. This is the default.
String
Adjust Z Value
(Optional)
A numeric value or field from the input features that will be used to adjust the z of each vertex in the input features. A positive value will shift the feature higher, while a negative number will shift it lower along the z-axis.
Double; Field
Convert From Units
(Optional)
Specifies the existing units of the z-values. This parameter is used in conjunction with the Convert To Units parameter.
  • Millimeters—The units will be millimeters.
  • Centimeters—The units will be centimeters.
  • Meters—The units will be meters.
  • Inches—The units will be inches.
  • Feet—The units will be feet.
  • Yards—The units will be yards.
  • Fathoms—The units will be fathoms.
String
Convert To Units
(Optional)
Specifies the units that existing z-values will be converted to.
String
Derived output
Updated Features
The updated input features.
Feature Layer
Environments
Current Workspace, Extent
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
