Feature Envelope To Polygon (Data Management Tools)
Summary
Creates a feature class containing polygons, each of which represents the envelope of an input feature.
Illustration
Feature Envelope To Polygon tool illustration
Usage
  • The attributes of the input features will be maintained in the output feature class. A new field, ORIG_FID, will be added to the output feature class and set to the input feature IDs.
  • Since the envelope of a perfectly horizontal line (parallel to the x-axis) has a zero height and the envelope of a perfectly vertical line (parallel to the y-axis) has a zero width, the resulting polygon from either line would have a zero area; such invalid polygons will be omitted in the output. The same applies to a part in a multipart line feature.
Parameters
Label Explanation Data type
Input Features
The input features that can be multipoint, line, polygon, or annotation.
Feature Layer
Output Feature Class
The output polygon feature class.
Feature Class
Create multipart features
(Optional)
Specifies whether to use one envelope for each entire multipart feature or one envelope per part of a multipart feature. This parameter will affect the results of multipart input features only.
  • Checked—Uses one envelope for each part of a multipart feature; the resulting polygon of the multipart feature will remain multipart.
  • Unchecked—Uses one envelope containing an entire multipart feature; therefore, the resulting polygon will be singlepart. This is the default.
Boolean
Environments
Current Workspace, Scratch Workspace, Default Output Z Value, M Resolution, M Tolerance, Output M Domain, Output Z Domain, Output Coordinate System, Extent, Output has M values, Output has Z values, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
