Calculate Geometry Attributes (Data Management Tools)
Summary
Adds information to a feature's attribute fields representing the spatial or geometric characteristics and location of each feature, such as length or area and x-, y-, z-coordinates, and m-values.
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • Length and area calculations will be in the units of the input features' coordinate system unless different units are selected in the Length Unit and Area Unit parameters. If the Coordinate System parameter is specified, the length and area calculations will be in the units of that coordinate system unless different units are specified in the Length Unit and Area Unit parameters.
    Learn more about length and area units in geoprocessing tools
  • Length and area calculations are not supported when the input features have a geographic coordinate system or a projected coordinate system based on Web Mercator. Length and area calculations are not accurate or valid in these coordinate systems. Choose the geodesic length or geodesic area property for best results.
  • The geodesic length and area properties use a shape-preserving algorithm. This produces highly accurate results that are not biased by an assumption that the input line or polygon features are constructed with geodesic arcs between the vertices, which is the assumption regarding traditional geodesic length and area.
  • If the input features have a selection, only the selected features will have values calculated; all other features will maintain their existing value.
Parameters
Label Explanation Data type
Input Features
The features with a field that will be updated with geometry calculations.
Feature Layer
Geometry Attributes
The fields in which the specified geometry properties will be calculated.
You can select an existing field or provide a new field name. If a new field name is provided, the field type is determined by the type of values that are written to the field. Count attributes are written to long integer fields; area, length, and x-, y-, z-coordinate, and m-value attributes are written to double fields; and coordinate notations such as Degrees Minutes Seconds or MGRS are written to text fields.
Unless otherwise noted, area and length properties are planar measurements using 2D Cartesian mathematics.
Value table columns:
  • Field (Existing or New)—Field in which to calculate a geometry property.
  • Property—Geometry property to calculate into the target field.
    • Area—An attribute will be added to store the area of each polygon feature.
    • Area (geodesic)—An attribute will be added to store the shape-preserving geodesic area of each polygon feature.
    • Centroid x-coordinate—An attribute will be added to store the centroid x-coordinate of each feature.
    • Centroid y-coordinate—An attribute will be added to store the centroid y-coordinate of each feature.
    • Centroid z-coordinate—An attribute will be added to store the centroid z-coordinate of each feature.
    • Centroid m-value—An attribute will be added to store the centroid m-value of each feature.
    • Central point x-coordinate—An attribute will be added to store the x-coordinate of a central point inside or on each feature. This point is the same as the centroid if the centroid is inside the feature; otherwise, it is an inner label point.
    • Central point y-coordinate—An attribute will be added to store the y-coordinate of a central point inside or on each feature. This point is the same as the centroid if the centroid is inside the feature; otherwise, it is an inner label point.
    • Central point z-coordinate—An attribute will be added to store the z-coordinate of a central point inside or on each feature. This point is the same as the centroid if the centroid is inside the feature; otherwise, it is an inner label point.
    • Central point m-value—An attribute will be added to store the m-value of a central point inside or on each feature. This point is the same as the centroid if the centroid is inside the feature; otherwise, it is an inner label point.
    • Number of curves—An attribute will be added to store the number of curves in each feature. Curves include elliptical arcs, circular arcs, and Bezier curves.
    • Number of holes—An attribute will be added to store the number of interior holes within each polygon feature.
    • Minimum x-coordinate—An attribute will be added to store the minimum x-coordinate of each feature's extent.
    • Minimum y-coordinate—An attribute will be added to store the minimum y-coordinate of each feature's extent.
    • Minimum z-coordinate—An attribute will be added to store the minimum z-coordinate of each feature's extent.
    • Maximum x-coordinate—An attribute will be added to store the maximum x-coordinate of each feature's extent.
    • Maximum y-coordinate—An attribute will be added to store the maximum y-coordinate of each feature's extent.
    • Maximum z-coordinate—An attribute will be added to store the maximum z-coordinate of each feature's extent.
    • Length—An attribute will be added to store the length of each line feature.
    • Length (geodesic)—An attribute will be added to store the shape-preserving geodesic length of each line feature.
    • Length (3D)—An attribute will be added to store the 3D length of each line feature.
    • Line bearing—An attribute will be added to store the start-to-end bearing of each line feature. Values range from 0 to 360, with 0 meaning north, 90 east, 180 south, 270 west, and so on.
    • Line start x-coordinate—An attribute will be added to store the x-coordinate of the start point of each line feature.
    • Line start y-coordinate—An attribute will be added to store the y-coordinate of the start point of each line feature.
    • Line start z-coordinate—An attribute will be added to store the z-coordinate of the start point of each line feature.
    • Line start m-value—An attribute will be added to store the m-value of the start point of each line feature.
    • Line end x-coordinate—An attribute will be added to store the x-coordinate of the end point of each line feature.
    • Line end y-coordinate—An attribute will be added to store the y-coordinate of the end point of each line feature.
    • Line end z-coordinate—An attribute will be added to store the z-coordinate of the end point of each line feature.
    • Line end m-value—An attribute will be added to store the m-value of the end point of each line feature.
    • Number of parts—An attribute will be added to store the number of parts composing each feature.
    • Number of vertices—An attribute will be added to store the number of points or vertices composing each feature.
    • Perimeter length—An attribute will be added to store the length of the perimeter or border of each polygon feature.
    • Perimeter length (geodesic)—An attribute will be added to store the shape-preserving geodesic length of the perimeter or border of each polygon feature.
    • Point x-coordinate—An attribute will be added to store the x-coordinate of each point feature.
    • Point y-coordinate—An attribute will be added to store the y-coordinate of each point feature.
    • Point z-coordinate—An attribute will be added to store the z-coordinate of each point feature.
    • Point m-value—An attribute will be added to store the m-value of each point feature.
    • Point x- and y-coordinate notation—An attribute will be added to store the x- and y-coordinate of each point feature formatted as a specified coordinate notation.
Value Table
Length Unit
(Optional)
Specifies the unit that will be used to calculate length.
  • Kilometers—The length unit will be kilometers.
  • Meters—The length unit will be meters.
  • Statute Miles—The length unit will be statute miles.
  • International Nautical Miles—The length unit will be international nautical miles.
  • International Yards—The length unit will be international yards.
  • International Feet—The length unit will be international feet.
  • US Survey Miles—The length unit will be US survey miles.
  • US Survey Nautical Miles—The length unit will be US survey nautical miles.
  • US Survey Yards—The length unit will be US survey yards.
  • US Survey Feet—The length unit will be US survey feet.
String
Area Unit
(Optional)
Specifies the unit that will be used to calculate area.
  • Square Kilometers—The area unit will be square kilometers.
  • Hectares—The area unit will be hectares.
  • Square Meters—The area unit will be square meters.
  • Square Statute Miles—The area unit will be square statute miles.
  • Square International Nautical Miles—The area unit will be square international nautical miles.
  • International Acres—The area unit will be international acres.
  • Square International Yards—The area unit will be square international yards.
  • Square International Feet—The area unit will be square international feet.
  • Square US Survey Miles—The area unit will be square US survey miles.
  • Square US Survey Nautical Miles—The area unit will be square US survey nautical miles.
  • US Survey Acres—The area unit will be US survey acres.
  • Square US Survey Yards—The area unit will be square US survey yards.
  • Square US Survey Feet—The area unit will be square US survey feet.
String
Coordinate System
(Optional)
The coordinate system in which the coordinates, length, and area will be calculated. The coordinate system of the input features is used by default.
Coordinate System
Coordinate Format
(Optional)
Specifies the coordinate format in which the x- and y-coordinates will be calculated. The coordinate format matching the input features' spatial reference units is used by default.
Several coordinate formats, including Degrees Minutes Seconds, Degrees Decimal Minutes, and others, require the calculation to be performed in a text field.
  • Same as input—The input features' spatial reference units will be used for coordinate formatting. This is the default.
  • Decimal Degrees—The coordinate format will be Decimal Degrees.
  • Degrees Minutes Seconds (DDD° MM' SSS.ss" <N|S|E|W>)—The coordinate format will be Degrees Minutes Seconds with cardinal direction component at the end (DDD° MM' SSS.ss" <N|S|E|W>).
  • Degrees Minutes Seconds (<N|S|E|W> DDD° MM' SSS.ss")—The coordinate format will be Degrees Minutes Seconds with cardinal direction component at the beginning (<N|S|E|W> DDD° MM' SSS.ss").
  • Degrees Minutes Seconds (<+|-> DDD° MM' SSS.ss")—The coordinate format will be Degrees Minutes Seconds with positive or negative direction component at the beginning (<+|-> DDD° MM' SSS.ss").
  • Degrees Minutes Seconds (<+|-> DDD.MMSSSss)—The coordinate format will be Degrees Minutes Seconds packed into a single value with positive or negative direction component at the beginning (<+|-> DDD.MMSSSss).
  • Degrees Decimal Minutes (DDD° MM.mmm' <N|S|E|W>)—The coordinate format will be Degrees Decimal Minutes with cardinal direction component at the end (DDD° MM.mmm' <N|S|E|W>).
  • Degrees Decimal Minutes (<N|S|E|W> DDD° MM.mmm')—The coordinate format will be Degrees Decimal Minutes with cardinal direction component at the beginning (<N|S|E|W> DDD° MM.mmm').
  • Degrees Decimal Minutes (<+|-> DDD° MM.mmm')—The coordinate format will be Degrees Decimal Minutes with positive or negative direction component at the beginning (<+|-> DDD° MM.mmm').
  • GARS (Global Area Reference System)—The coordinate format will be Global Area Reference System. The Global Area Reference System is based on latitude and longitude, dividing and subdividing the world into cells.
  • GEOREF (World Geographic Reference System)—The coordinate format will be World Geographic Reference System. The World Geographic Reference System is based on the geographic system of latitude and longitude, but using a simpler and more flexible notation.
  • MGRS (Military Grid Reference System)—The coordinate format will be Military Grid Reference System.
  • USNG (United States National Grid)—The coordinate format will be United States National Grid.
  • UTM (Universal Transverse Mercator)—The coordinate format will be Universal Transverse Mercator.
  • UTM with no spaces—The coordinate format will be Universal Transverse Mercator with no spaces.
String
Derived output
Updated Features
The updated input features.
Feature Layer
Environments
Output Coordinate System, Geographic Transformations, Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
