Multipart To Singlepart (Data Management Tools)
Summary
Creates a feature class of singlepart features by separating multipart input features.
Illustration
Multipart to Singlepart tool illustration
Usage
  • The attributes of the input features will be maintained in the output feature class. A new field, ORIG_FID, will be added to the output feature class and set to the input feature IDs.
  • Each part of a multipart feature will be separated into individual features in the output feature class. Features that are already singlepart will not be affected.
  • Most of the output feature types will be the same as input (input polygons remain polygons; input lines remain lines). If the input features are of type multipoint, the output feature class will be type point.
  • To reconstruct multipart features from singlepart features based on a common field value, such as ORIG_FID, use the Dissolve tool.
  • A multipatch feature will be separated into its constituent geometry parts. Each part can be defined by a collection of vertices containing x-, y-, and z-coordinates that are arranged as follows:
    • Individual triangles that reference three vertices.
    • Triangle strips that are defined by multiple triangles that successively share one common edge.
    • Triangle fans that are defined by multiple triangles with a common point of origin.
    • Rings that represent a coplanar region whose boundary is defined by four or more vertices.
Parameters
Label Explanation Data type
Input Features
The input features that can be any feature type.
Feature Layer
Output Feature Class
The output feature class containing features that vary by input feature type.
Feature Class
Environments
Current Workspace, Scratch Workspace, Default Output Z Value, M Resolution, M Tolerance, Output M Domain, Output Z Domain, Output Coordinate System, Extent, Output has M values, Output has Z values, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
