Minimum Bounding Geometry (Data Management Tools)
Summary
Creates a feature class containing polygons which represent a specified minimum bounding geometry enclosing each input feature or each group of input features.
Illustration
Minimum Bounding Geometry tool illustration
Usage
  • The output polygon features and their attributes will vary depending on the specified geometry type and grouping choices.
  • The Group Option parameter will affect the output polygons and attributes in the following ways:
    • Using None, none of the input features will be grouped. An output polygon feature will be created for each input feature; the resulting polygons may overlap. The attributes of the input features will be maintained in the output feature class. A new field, ORIG_FID, will be added to the output feature class and set to the input feature IDs.
    • Using All, one output polygon feature will be created for all input features. The attributes of the input features will not be maintained in the output feature class.
    • Using List, each set of input features with the same field values in the specified group fields will be treated as a group. An output polygon feature will be created for each group; the resulting polygons may overlap. The attributes of the input features used as the group field or fields will be maintained in the output feature class.
  • Each geometry type can be characterized by one or more unique measurements; these measurements can optionally be added to the output as new fields as described below. The width, length, and diameter values are in feature units; the orientation angles are in decimal degrees clockwise from north. The prefix, MBG_, indicates minimum bounding geometry field.
    • For the Rectangle by area and Rectangle by width options, the new fields and measurements are the following:
      • MBG_Width—The length of the shorter side of the resulting rectangle.
      • MBG_Length—The length of the longer side of the resulting rectangle.
      • MBG_Orientation—The orientation of the longer side of the resulting rectangle.
    • For the Envelope option, the new fields and measurements are the following:
    • For the Convex hull option, the new fields and measurements are the following:
      • MBG_Width—The shortest distance between any two vertices of the convex hull. (It may be found between more than one pair of vertices, but the first found will be used.)
      • MBG_Length—The longest distance between any two vertices of the convex hull; these vertices are called antipodal pairs or antipodal points. (It may be found between more than one pair of vertices, but the first found will be used.)
      • MBG_APodX1—The x-coordinate of the first point of the antipodal pairs.
      • MBG_APodY1—The y-coordinate of the first point of the antipodal pairs.
      • MBG_APodX2—The x-coordinate of the second point of the antipodal pairs.
      • MBG_APodY2—The y-coordinate of the second point of the antipodal pairs.
      • MBG_Orientation—The orientation of the imagined line connecting the antipodal pairs.
    • For Circle, the new field and measurement are the following:
      • MBG_Diameter—The diameter of the resulting circle.
  • There are special cases of input features that would result in invalid (zero-area) output polygons. In these cases, a small value derived from the input feature XY Tolerance will be used as the width, length, or diameter to create output polygons. These polygons serve as place holders for keeping track of features. If the resulting polygons appear invisible using the default polygon outline width, change to a thicker outline line symbol to display them. Examples of these cases include the following:
    • If a multipoint feature contains only one point or a group of such features are coincident, a very small square polygon will be created around the point for geometry types Rectangle by area, Rectangle by width, Convex hull, and Envelope; and a very small circle for geometry type Circle. The MBG_Width, MBG_Length, MBG_Orientation, and MBG_Diameter values will be set to zero to indicate these cases.
    • If an input feature or a group of input features are perfectly aligned, for example, a horizontal or vertical line or a two-point multipoint feature, a rectangle polygon with a very small width will be created around the feature. This applies to geometry types Rectangle by area, Rectangle by width, Convex hull, and Envelope; the resulting MBG_Width value will be set to zero to indicate these cases.
Parameters
Label Explanation Data type
Input Features
The input features that can be point, multipoint, line, polygon, or multipatch.
Feature Layer
Output Feature Class
The output polygon feature class.
Feature Class
Geometry Type
(Optional)
Specifies what type of minimum bounding geometry the output polygons will represent.
  • Rectangle by area—The rectangle of the smallest area enclosing an input feature. This is the default.
  • Rectangle by width—The rectangle of the smallest width enclosing an input feature.
  • Convex hull—The smallest convex polygon enclosing an input feature.
  • Circle—The smallest circle enclosing an input feature envelope.
  • Envelope—The envelope of an input feature.
String
Group Option
(Optional)
Specifies how the input features will be grouped; each group will be enclosed with one output polygon.
  • None—Input features will not be grouped. This is the default. This option is not available for point input.
  • All—All input features will be treated as one group.
  • List—Input features will be grouped based on their common values in the specified field or fields in the group field parameter.
String
Group Fields
(Optional)
The field or fields in the input features that will be used to group features, when List is specified as Group Option. At least one group field is required for List option. All features that have the same value in the specified field or fields will be treated as a group.
Field
Add geometry characteristics as attributes to output
(Optional)
Specifies whether to add the geometric attributes in the output feature class or omit them in the output feature class.
  • Checked—Adds the geometric attributes in the output feature class.
  • Unchecked—Omits any input attributes in the output feature class. This is the default.
Boolean
Environments
Current Workspace, Scratch Workspace, Default Output Z Value, M Resolution, M Tolerance, Output M Domain, Output Z Domain, Output Coordinate System, Extent, Output has M values, Output has Z values, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
