Add XY Coordinates (Data Management Tools)
Summary
Adds the fields POINT_X and POINT_Y to the point input features and calculates their values. The tool also appends the POINT_Z and POINT_M fields if the input features are z- and m-enabled.
Illustration
Add XY Coordinates tool illustration
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • If the POINT_X, POINT_Y, POINT_Z, and POINT_M fields exist, their values are recalculated.
  • The output POINT_X and POINT_Y field values are based on the coordinate system of the dataset, not the coordinate system of the map display. To force the POINT_X and POINT_Y values to be in a coordinate system different than the input dataset, set the Output Coordinate System environment.
  • If points are moved after using Add XY Coordinates, their POINT_X and POINT_Y values, and POINT_Z and POINT_M values—if present—must be recomputed by running Add XY Coordinates again.
  • The Project tool does not modify the values of POINT_X, POINT_Y, POINT_Z, or POINT_M fields.
  • If the input features are in a geographic coordinate system, POINT_X and POINT_Y represent the longitude and latitude, respectively.
Parameters
Label Explanation Data type
Input Features
The point features whose x,y coordinates will be appended as POINT_X and POINT_Y fields.
Feature Layer
Derived output
Updated Input Features
The updated input features.
Feature Layer
Environments
Current Workspace, Extent, Output Coordinate System, Geographic Transformations
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
