Feature To Point (Data Management Tools)
Summary
Creates a feature class containing points generated from the centroids of the input features or placed within the input features.
Illustration
Feature To Point tool illustration
Usage
  • The attributes of the input features will be maintained in the output feature class. A new field, ORIG_FID, will be added to the output feature class and set to the input feature IDs.
Parameters
Label Explanation Data type
Input Features
The input features, which can be multipoint, line, polygon, or annotation.
Feature Layer
Output Feature Class
The output point feature class.
Feature Class
Inside
(Optional)
Specifies whether an output point will be located within the input feature or at the centroid of the input feature.
If this parameter is unchecked, the location of each output point will be determined as follows:
  • Multipoint features—The output point will be located at the average x- and y-coordinate of all the points in the multipoint.
  • Polyline features—The output point will be located at the weighted average x- and y-coordinate of the midpoints of all line segments in the line where the weight of a particular midpoint is the length of the correspondent line segment. Parametric (true) curves will be densified.
  • Polygon features—The output point will be located at the center of gravity (centroid) of the polygon.
If this parameter is checked, the location of the representative point of an input feature will be contained by the input feature and determined as follows:
  • Multipoint features—The output point will be coincident with one of the points in the multipoint.
  • Polyline features—The output point will be on the line. If the line is a parametric (true) curve, the output point will be at the midpoint of the line.
  • Polygon features—The output point will be inside the polygon.
  • Checked—The output point will be located within the input feature.
  • Unchecked—The output point will be located at the centroid of the input feature. The output point may not always be contained by the input feature. This is the default.
Boolean
Environments
Current Workspace, Scratch Workspace, Default Output Z Value, M Resolution, M Tolerance, Output M Domain, Output Z Domain, Output Coordinate System, Extent, Output has M values, Output has Z values, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
