Table To Ellipse (Data Management Tools)
Summary
Creates a feature class containing geodetic or planar ellipses from the values in an x-coordinate field, y-coordinate field, major axis and minor axis fields, and azimuth field of a table.
Illustration
Table To Ellipse tool illustration
Usage
  • Output ellipses are constructed from field values. The field values include the following:
    • The x- and y-coordinates of a center point
    • The major and minor axis lengths
    • The azimuth angle
    The fields and their values will be included in the output.
  • When the output ellipsis are geodetic, the x- and y-coordinates and the lengths of the major and minor axes are measured on the surface of the earth, and the azimuth angle is measured from north. When the output ellipsis are planar, the x- and y-coordinates and the lengths of the major and minor axes are measured on the projected plane, and the azimuth angle is measured clockwise from grid north (vertical up on the map).
  • A geodetic ellipse is a curve on the surface of the earth. However, a geodetic ellipse feature is not stored as a parametric (true) curve in the output; it is stored as a densified polyline representing the path of the geodetic ellipse.
  • If you specify the same field for both the Major Field and Minor Field parameters, or if the values in both fields are equal, the output features represent geodetic circles.
  • When the output is a feature class in a geodatabase, the values in the Shape_Length field are always in the units of the output coordinate system specified by the Spatial Reference parameter, and they are the planar lengths of the polylines. To measure a geodesic length or distance, use the ArcGIS Pro Measure tool and choose the Geodesic, Loxodrome, or Great Elliptic option accordingly before taking a measurement.
  • By default, the output will be a line feature class. To create a polygon feature class, specify the Geometry Type parameter value as Polygon.
Parameters
Label Explanation Data type
Input Table
The input table. It can be a text file, CSV file, Excel file, dBASE table, or geodatabase table.
Table View
Output Feature Class
The output feature class that will contain geodetic or planar ellipses.
Feature Class
X Field
A numerical field in the input table containing the x-coordinates (or longitudes) of the center points of ellipses to be positioned in the output coordinate system specified by the Spatial Reference parameter.
Field
Y Field
A numerical field in the input table containing the y-coordinates (or latitudes) of the center points of ellipses to be positioned in the output coordinate system specified by the Spatial Reference parameter.
Field
Major Field
A numerical field in the input table containing major axis lengths of the ellipses.
Field
Minor Field
A numerical field in the input table containing minor axis lengths of the ellipses.
Field
Distance Units
Specifies the units that will be used for the Major Field and Minor Field parameters.
  • Meters—The units will be meters.
  • Kilometers—The units will be kilometers.
  • Miles—The units will be miles.
  • Nautical miles—The units will be nautical miles.
  • Feet—The units will be feet.
  • U.S. survey feet—The units will be U.S. survey feet.
String
Azimuth Field
(Optional)
A numerical field in the input table containing azimuth angle values for the major axis rotations of the output ellipses. The values are measured clockwise from north.
Field
Azimuth Units
(Optional)
Specifies the units that will be used for the Azimuth Field parameter.
  • Decimal degrees—The units will be decimal degrees. This is the default.
  • Mils—The units will be mils.
  • Radians—The units will be radians.
  • Gradians—The units will be gradians.
String
ID
(Optional)
A field in the input table. This field and the values are included in the output and can be used to join the output features with the records in the input table.
Field
Spatial Reference
(Optional)
The spatial reference of the output feature class. The default is GCS_WGS_1984 or the input coordinate system if it is not Unknown.
Spatial Reference
Preserve attributes
(Optional)
Specifies whether the remaining input fields will be added to the output feature class.
  • Checked—The remaining input fields will be added to the output feature class. A new field, ORIG_FID, will also be added to the output feature class to store the input feature ID values.
  • Unchecked—The remaining input fields will not be added to the output feature class. This is the default.
Boolean
Geometry Type
(Optional)
Specifies the geometry type for the output feature class.
  • Line—An output polyline feature class will be created. This is the default.
  • Polygon—An output polygon feature class will be created.
String
Method
(Optional)
Specifies whether the ellipse will be generated based on geodesic or planar measurements.
  • Geodesic—A geodesic ellipse will be generated. The ellipse will accurately represent the shape on the surface of the earth. This is the default.
  • Planar—A planar ellipse will be generated on the projected plane. It usually does not accurately represent the shape on the surface of the earth as a geodesic ellipse does. This option is not available for geographic coordinate systems.
String
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
