Delete Features (Data Management Tools)
Summary
Deletes all or the selected subset of features from the input.
The deletion of all features or a subset of features depends on the following:
If the input is a feature class, all features will be deleted.
If the input is a layer with no selection, all features will be deleted.
If the input is a layer with a selection, only the selected features will be deleted.
Usage
This tool accepts layers with selections as input and will delete only those features that are selected. To delete specific features from a feature class, convert the feature class to a layer using the Make Feature Layer tool or by adding it to the display. A selection can then be applied using the Select Layer By Attribute or Select Layer By Location tool, by querying a map layer, or by selecting features interactively using selection tools from the Selection group on the Map tab.
Deleting all features from a feature class with a large number of features can take time. If the intent is to delete all the features, consider using the Truncate Table tool instead. See the Truncate Table documentation for important cautionary statements on its use.
This tool deletes both the geometry and attributes of the Input Features value.
The Extent environment is honored by this tool. Only the features that are within or intersect the output extent environment will be deleted. If the input layer has a selection, only the selected features that are within or intersect the output extent will be deleted.
Parameters
| Label | Explanation | Data type |
Input Features |
The feature class, shapefile, or layer containing features to be deleted. |
Feature Layer |
Derived output
Output Feature Class |
The updated feature class. |
Feature Layer |
Environments
Special cases
- Extent
Only those features that are within or intersect the extent will be deleted.
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
