Copy Features (Data Management Tools)
Summary
Copies features from the input feature class or layer to a new feature class.
Usage
If the input is a layer and has a selection, only the selected features are copied to the output feature class.
Both the geometry and attributes of the Input Features will be copied to the output feature class.
This tool can be used for data conversion as it can read many feature formats (any you can add to a map) and write these to shapefile or geodatabase.
Parameters
| Label | Explanation | Data type |
Input Features |
The features to be copied. |
Feature Layer |
Output Feature Class |
The feature class which will be created and to which the features will be copied. |
Feature Class |
Configuration Keyword (Optional) |
Geodatabase configuration keyword to be applied if the output is a geodatabase. |
String |
Output Spatial Grid 1 (Optional) |
This parameter has been deprecated in ArcGIS Pro. Any value you enter is ignored. |
Double |
Output Spatial Grid 2 (Optional) |
Double |
Output Spatial Grid 3 (Optional) |
Double |
Environments
Current Workspace, Scratch Workspace, Output Coordinate System, Geographic Transformations, Extent, XY Resolution, XY Tolerance, Output has M values, M Resolution, M Tolerance, Output has Z values, Default Output Z Value, Z Resolution, Z Tolerance, Maintain fully qualified field names, Output CONFIG Keyword, Maintain Attachments, Auto Commit, Output XY Domain, Output M Domain, Output Z Domain, Preserve Global IDs
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
