Maintain Attachments (Environment setting)
Tools that honor the Maintain Attachments environment will copy attachments from the input features to the output features. An attachment table and a relationship class will be created.
Usage notes
  • The input feature class must have attachments. This setting will not otherwise create or enable attachments on the output.
  • The output workspace must support attachments. Attachments will not be copied if the output workspace does not support attachments; for example, shapefiles and DBF files do not support attachments.
  • The following tools transfer attachments:
  • The Copy tool always copies attachments, regardless of the Maintain Attachments environment setting.
Dialog syntax
  • Checked—Attachments will be copied to the output feature class. This is the default.
  • Unchecked—Attachments will not be copied to the output.
Python syntax
arcpy.env.maintainAttachments = boolean_option
Name Explanation
boolean_option
  • Specifies whether attachments will be copied to the output features. The default is True.
Scripting syntax
import arcpy
# Set the maintainAttachments environment to False (no attachment copy)
arcpy.env.maintainAttachments = False
