Copy Rows (Data Management Tools)
Summary
Copies the rows of a table to a different table.
Usage
  • The tool copies the rows of a table, table view, feature class, feature layer, delimited file, or raster with an attribute table to a new geodatabase or dBASE table or a delimited file.
  • This tool supports the following table formats as input:
    • Geodatabase
    • dBASE (.dbf)
    • Microsoft Excel worksheets (.xls and .xlsx)
    • Memory-based tables
    • Delimited files
      • Comma-delimited files (.csv, .txt, and .asc)
      • Tab-delimited files (.tsv and .tab)
      • Pipe-delimited files (.psv)
    For delimited files, the first row of the input file is used as the field names on the output table. Field names cannot contain spaces or special characters (such as $ or *), and an error will occur if the first row of the input file contains spaces or special characters.
  • The tool can be used to output a delimited file by adding one of the following file extensions to the output name in a folder workspace:
    • Comma-delimited files (.csv, .txt, or .asc)
    • Tab-delimited files (.tsv or .tab)
  • If the input is a table view or feature layer and has a selection, only the selected rows will be copied to the output table.
  • All rows will be copied if the input is a feature class or table. If the input rows are from a layer or table view that has a selection, only the selected features or rows will be used.
  • If the Input Rows parameter value is a feature class, only the attributes, not the geometry, will be copied to the output table.
  • To add or append the copied rows to an existing table, use the Append tool.
Parameters
Label Explanation Data type
Input Rows
The input rows to be copied to a new table.
Table View; Raster Layer
Output Table
The table that will be created and to which rows from the input will be copied.
If the output table is in a folder, include an extension such as .csv, .txt, or .dbf to make the table the specified format. If the output table is in a geodatabase, do not specify an extension.
Table
Configuration Keyword
(Optional)
The default storage parameters for an enterprise geodatabase.
String
Environments
Current Workspace, Output CONFIG Keyword, Maintain Attachments, Scratch Workspace, Extent, Preserve Global IDs
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
