Subdivide Polygon (Data Management Tools)
Summary
Divides polygon features into a number of equal areas or parts.
Usage
  • Euclidean or planar calculations are used to determine areas of polygon subdivisions. For best results, use an equal area, projected coordinate system that minimizes area distortion for polygons in your data's geographic location.
    Learn more about projected coordinate systems
  • Attribute values from the input feature classes will be copied to the output feature class. However, if the input is a layer or layers created by the Make Feature Layer tool and a field's Use Ratio Policy option is checked, a ratio of the input attribute value is calculated for the output attribute value. When Use Ratio Policy is checked, whenever a feature in an overlay operation is split, the attributes of the resulting features are a ratio of the attribute value of the input feature. The output value is based on the ratio into which the input feature geometry was divided. For example, If the input geometry was divided equally, each new feature's attribute value is assigned one-half of the input feature's attribute value. Use Ratio Policy only applies to numeric field types.
  • The Subdivide Polygon tool honors the Parallel Processing Factor environment. If the environment is not set (the default) or is set to 100, full parallel processing will be enabled and the tool will attempt to distribute the work to all the logical cores on the machine. Setting the environment to 0 will disable parallel processing. Specifying a factor between 1 and 99 will cause the tool to determine the percentage of logical cores to use by applying the formula (Parallel Processing Factor / 100 * Logical Cores) rounded up to the nearest integer. If the result of this formula is 0 or 1, parallel processing will not be enabled.
Parameters
Label Explanation Data type
Input Features
The polygon features to be subdivided.
Feature Layer
Output Feature Class
The output feature class of subdivided polygons.
Feature Class
Subdivision Method
Specifies the method that will be used to divide the polygons.
  • Number of equal parts—Polygons will be divided evenly into a number of parts. This is the default.
  • Equal areas—Polygons will be divided into a specified number of parts of a certain area, and a remainder part.
String
Number of Areas
(Optional)
The number of areas into which the polygon will be divided if the Number of equal parts subdivision method is specified.
Long
Target Area
(Optional)
The area of the equal parts if the Equal areas subdivision method is specified. If the Target Area is larger than the area of the input polygon, the polygon will not be subdivided.
Areal Unit
RESERVED
(Optional)
This parameter is not yet supported.
Linear Unit
Split Angle
(Optional)
The angle that will be used to draw the lines that divide the polygon. The default is 0.
Double
Subdivision Type
(Optional)
Specifies how the polygons will be divided.
  • Strips—Polygons will be divided into strips. This is the default.
  • Stacked blocks—Polygons will be divided into stacked blocks.
String
Environments
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
