An overview of the Data Management toolbox
The Data Management toolbox contains tools that are used to develop, manage, and maintain feature classes, datasets, layers, and raster data structures.
Toolset
3D Objects
The 3D Objects toolset contains tools for enhancing a multipatch feature class with the capabilities of the 3D object feature layer. The 3D object feature layer improves multipatch features by optimizing the storage of texture information and adding support for additional visualization effects, textures, and materials associated with several 3D modeling formats.
Archiving
The Archiving toolset contains tools for managing geodatabase archiving. Archiving in ArcGIS provides the functionality to record and access changes made to data in a geodatabase. Geodatabase archiving is the mechanism for capturing, managing, and analyzing data change.
The Attachments toolset contains tools for managing geodatabase attachments. The attachments functionality provides a way to associate nongeographic data with geographic information. With these tools, you can incorporate attachments into your workflows and automate the process of adding and removing attachments.
Attribute Rules
The Attribute Rules toolset contains tools for managing geodatabase attribute rules. Attribute rule functionality provides a way to add custom rules and behavior to geodatabase data. With these geoprocessing tools you can incorporate attribute rules into workflows and automate the process of adding and removing rules.
Catalog Dataset
The Catalog Dataset toolset contains tools for creating, maintaining, and updating catalog datasets. A catalog dataset is visualized as a catalog layer, which is used to explore and organize disparate content from one centrally managed source.
Contingent Values
The Contingent Values toolset contains tools for managing geodatabase contingent values and field groups. Contingent values functionality provides a way to add custom behavior to geodatabase data. You can incorporate contingent values into your workflows and automate the process of adding and removing values using these tools.
Data Comparison
The Data Comparison toolset contains tools to compare one dataset with another dataset to report similarities and differences. You can use these tools to identify changes made to a dataset.
Data Loading
The Data Loading toolset contains tools to streamline data loading from a source schema to a target schema. The tools help reduce the time and complexity of migrating to a new data schema.
Distributed Geodatabase
The Distributed Geodatabase toolset contains tools that create and synchronize changes between replica geodatabases.
Domains
The Domains toolset contains tools to create and edit domains to manage attribute fields.
Feature Binning
The Feature Binning toolset contains tools for managing feature binning. Feature binning is an advanced visualization capability that allows users to explore and visualize large datasets. It also helps users observe patterns at macro and micro levels with simple out-of-the-box mapping options.
Feature Class
The Feature Class toolset contains tools that perform basic feature class management.
Features
The Features toolset contains tools to create and manage feature-based GIS data, transform features from one geometry type to another, find and correct issues with feature geometry, and record feature geometry measurements and coordinates as attributes.
Fields
The Fields toolset contains tools for creating, modifying, and deleting fields. A field is a column in a table; each field contains the values for a single attribute. Any number of fields can be included in a table. Field settings can be specified, such as the field type and the maximum size of the data that can be stored in it.
File Geodatabase
The File Geodatabase toolset contains tools for compressing, uncompressing, and licensing file geodatabases.
General
The General toolset contains tools for performing general data management operations. The toolset contains tools for combining feature classes or tables; renaming, copying, or deleting datasets; finding or deleting duplicate or identical records; sorting records; and uploading files to a portal.
Generalization
The Generalization toolset contains tools for dissolving or eliminating features.
Geodatabase Administration
The Geodatabase Administration toolset contains tools for a variety of geodatabase management tasks. Specific geodatabase data management tools as well as geodatabase upgrade, management, and maintenance are covered by the tools in this toolset.
Indexes
The Indexes toolset contains tools for creating and removing attribute or spatial indexes.
Joins and Relates
The Joins and Relates toolset contains tools that add or remove joins between layers or table views. Joins made with the Add Join tool or the Add Spatial Join tool or relates made with the Add Relate tool are temporary and do not permanently transfer the fields between tables. To preserve the join or relate between sessions, you can create a relationship using the tools in the Relationship Classes toolset.
LAS Dataset
The LAS Dataset toolset contains tools for creating, managing, and optimizing a LAS dataset. The LAS dataset data type references collections of LAS files, making them easier to process, visualize, and analyze.
Layers and Table Views
The Layers and Table Views toolset contains tools for creating and manipulating layers, layer files, and table views.
Layout
The Layout toolset contains a tool for exporting multiple layouts to a specified export format.
Package
The Package toolset contains tools to consolidate, package, and share layers, maps, projects, address locators, and geoprocessing results.
Photos
The Photos toolset contains tools for analyzing and managing digital photograph files. The toolset includes tools for creating a point feature class from geotagged photo files (photos that were captured from a GPS camera device or a smartphone) and matching photo files to features or table rows based on the time stamp of the photo.
Projections and Transformations
The Projections and Transformations toolset contains tools for converting geographic data between coordinate systems. There are additional tools for transforming raster datasets, such as shift, rescale, and rotate.
Raster
The Raster toolset contains tools that perform raster data management and raster processing. These tools allow you to work with raster dataset properties and create and process raster data.
The Relationship Classes toolset contains tools for creating relationship classes.
Reports
The Reports toolset contains tools for exporting a report from an ArcGIS Pro project or a report file (.rptx) to PDF or Microsoft Excel formats.
Sampling
The Sampling toolset contains tools that create features used as either sampling locations or aggregation areas.
Spectral Library toolset
The Spectral Library toolset contains a tool for resampling the spectra of a spectral signature library.
Subtypes
The Subtypes toolset contains tools that create and edit subtypes, which provide a method of dividing feature classes or tables into logical groupings based on an attribute value.
Table
The Table toolset contains tools that perform basic table management.
Tile Cache
The Tile Cache toolset contains tools to generate, manage, import, and export tile caches. These tools are capable of generating tile caches from a raster dataset or a mosaic dataset on your desktop without the need for ArcGIS Server. These tile caches can then be shared as tile packages on ArcGIS Online and published as tiled map services.
Toolbox
The Toolbox toolset contains tools for analyzing the contents of toolboxes (model and script tools) for use with different versions of ArcGIS software.
Topology
The Topology toolset contains a set of tools that can be used to create and manage a geodatabase topology.
Trajectory Dataset
The Trajectory Dataset toolset contains tools that manage satellite altimetry data and derived products.
Versions
The Versions toolset contains tools to manage the versioning process.
Workspace
The Workspace toolset contains tools to create several data storage structures used by ArcGIS.
Toolsets in the Data Management toolbox
